-   -   Setting carrera 3.2 help / multimeter (http://forums.pelicanparts.com/porsche-911-technical-forum/1138844-setting-carrera-3-2-help-multimeter.html)
jimtweet 04-25-2023 07:03 AM
Trying to dial in 3.2 carrera idle and came across this video. Can anyone tell me what she has these leads hooked up to that she’s reading RPM like this
http://forums.pelicanparts.com/uploa...1682431417.jpg
darrin 04-25-2023 07:18 AM
this thread might help -- looks like you'd use the black wire from the O2 sensor (after warming up the car/o2 sensor) https://rennlist.com/forums/911-forum/446704-3-2-idle-speed-adjustment.html
Classic 911 04-25-2023 07:50 AM
Following
76FJ55 04-25-2023 09:14 AM
That would be the first part of the video where they were testing the O2 sensor for functioning.
I believe the OP was wandering about the later part of the video at around the 12:30 time frame. If you look at the meter she is using it is an automotive specific meter as she has the TACH(X10) range and 6CYL setting selected. It is most likely attached to the ignition coil lead and is using the pulsed current flow at the ignition coil primary winding to determine the engine RPM.
proporsche 04-25-2023 11:53 AM
[QUOTE=jimtweet;11982606]Trying to dial in 3.2 carrera idle and came across this video. Can anyone tell me what she has these leads hooked up to that she’s reading RPM like this
you can use simple timing light with digi. display on it...to set the rpm
Ivan
almostordinary 11-12-2023 12:07 PM
Getting to the bottom of my 3.2 with this same tool.
It's available on Amazon.
https://www.amazon.com/Sinometer-Automotive-Multimeter-Thermometer-Carrying/dp/B01NAUUOLQ/ref=sr_1_1?crid=1YEPQFOTAXIDE&keywords=hp9810+sino meter&qid=1699819600&sprefix=hp9810+sinomete%2Caps %2C124&sr=8-1
-Ian
fallingat120mph 12-14-2023 05:11 PM
Originally Posted by almostordinary (Post 12130126)
How did it work/has it worked for you? Am about to order this same one.
Erik
