Setting carrera 3.2 help / multimeter
Trying to dial in 3.2 carrera idle and came across this video. Can anyone tell me what she has these leads hooked up to that she’s reading RPM like this
Instagram: @TuitTech |
this thread might help -- looks like you'd use the black wire from the O2 sensor (after warming up the car/o2 sensor) https://rennlist.com/forums/911-forum/446704-3-2-idle-speed-adjustment.html
Following
Sent from my iPhone using Tapatalk |
I believe the OP was wandering about the later part of the video at around the 12:30 time frame. If you look at the meter she is using it is an automotive specific meter as she has the TACH(X10) range and 6CYL setting selected. It is most likely attached to the ignition coil lead and is using the pulsed current flow at the ignition coil primary winding to determine the engine RPM. |
[QUOTE=jimtweet;11982606]Trying to dial in 3.2 carrera idle and came across this video. Can anyone tell me what she has these leads hooked up to that she’s reading RPM like this
you can use simple timing light with digi. display on it...to set the rpm Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Getting to the bottom of my 3.2 with this same tool.
It's available on Amazon. https://www.amazon.com/Sinometer-Automotive-Multimeter-Thermometer-Carrying/dp/B01NAUUOLQ/ref=sr_1_1?crid=1YEPQFOTAXIDE&keywords=hp9810+sinometer&qid=1699819600&sprefix=hp9810+sinomete%2Caps%2C124&sr=8-1 -Ian |
How did it work/has it worked for you? Am about to order this same one. Erik
1986 911 Coupe 1986 911 Targa |
