H5 Headlight refresh (before & after pics)
Hi all,
I was replacing a cracked lens/reflector assembly and decided to clean up the used one I had purchased from fellow Pelican lobster (thanks Dane were better than expected. The process was to simply remove the headlights and separate the lens / reflector from the bucket assembly, then remove the bulb and the air filter (rectangular piece of plastic that is screwed to the bottom portion of the reflector). Pour some alcohol into the lens and cover the bulb hole and air filter hole with your hands and shake violently Then empty the alcohol and wait for the lens to dry completely. You can speed this along if you have an air compressor to blow out the lens, just make sure your not blasting dust or other contaminants into the lens. Have a look at the results. Side by side - Before - After - I'm going to take the cracked lens and do a couple of experiments ... one of which will be to add a small amount of salt to the alcohol to use as a mild abrasive - I'll report back w/ the results. Cheers,
ßrandon |
Way cool idea, Brandon.
We used to use ice and salt as an abrasive to clean coffee pots that were left on the heat empty. Worked great.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
I need to do that in a bad way.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
good stuff, Brandon. Somebody, somewhere posted that H5s suck for some reason, not really sure why. Does Porsche make mistakes? I understand the need for adequate roadway illumination (esp at speed) but is not this whole H4 retrofit thing a little overblown? Experienced hands here, please chime in.
" … a high performance, highly engineered Road Car … " 1989 Carrera 1989 928 S4 |
Brandon thanks for the cleaning tip.
What is the purpose of the metal clip around the bulb? Mine came loose and I can't seem to figure out how to put it back on without opening the housing. Thanks, Dan.
82 Coupe SC 87 928S4 Five Speed (Sold) 89 911 Silver Anniversary Coupe (sold) Laughter is still the best medicine. |
Could be wrong, but I just had the same thing happen to mine. I was thinking of how I could glue mine back in. Don't think it is possible. Doug
1971 RSR - interpretation |
GFCC
Brandon, Great tip. I did mine yesterday and they turned out great. All I need to do now is polish out some of the rock chips on the face and they will look brand new.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
My H5 headlights didn't seem very bright when driving on dark roads at night. The stock wattage was 60/55 for low/high beam. I tried several brands of "bright white" and "cool blue" bulbs, but I still wanted more. I looked at the price of H4’s about $350 and while within my budget decided I could take a DIY approach and see if my H5’s could be just as good. Also there seems to be a problem mounting the H4’s due to only a single screw holding them in place. There is a workaround suggested of Tie Wrapping the lens in place...Not very Porsche like if you ask me. Good light is an essential safety requirement. It seems to me that installing new H4’s after having old cloudy low-watt H5’s can give the impression that the H5 is crapola. IMHO my original H5 Lighting quality could have been compromised by: Poor wiring Faulty lighting switche Faulty charging system Scratched or pitted headlamp lens Reflector corrosion Dust Damaged headlamp bulb (loss of transparency of the glass) Poor headlamp aim On my car I also found a damaged bulb holder when the PO had broken the retaining ring on the lens so he glued the bulb into the lens...sigh... I installed the Marcus Sucro relay kit and immediately can see a diff with lamps getting a real 12v. $25.00 80/100 bulbs rated 5800K Super White. (The color of natural sunlight is 5250Kelvin) $29.00 Clean the lens with alcohol $0.0 (very cool idea, Brandon) With careful aiming completed, I now have bright white H5’s that are nearly night and day difference from the old. total cost : $54.00
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" Last edited by Seeeu911; 10-23-2005 at 08:19 AM.. |
Seeeu911, you're the man. Perfect summation of disparate bits of info, nicely tied together. THANKS.
Seeeu, I started reading your description, and I thought (before I got to it) that you should install a relay kit, and thus have the lamps isolated, AND on new wiring.
Sounds like it did the trick!
Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" |
Hey guys,
Glad you guys found this useful! The metal tab is indeed a light shield. For those that are missing it here is a simple drawing I put together to show the bulb to light shield orientation. If you look closely I also illustrated why the shield is not necessary with modern bulbs .. notice the painted end of the bulb. There are definitely mixed opinions when it comes to the H4/H5 debate. The output difference is marginal. All things being equal (lens/reflector clarity, bulb type and wattage, relays installed, etc) I think most would be hard pressed to tell the difference from the cab of the car or viewing the car coming at you. One of the other experiments I'm going to be playing with is to add City Lights to the H5 lens / reflector assembly.
ßrandon |
Seeeu911:
I would be interested in your comments after running the "improved" H5s for 2+ months now. Are you still satisfied with the light output? Have you had any heat-related issues from the 80/100 bulbs?
1997 Carrera 993 coupe - Slate Grey Metallic / Classic Grey 1989 Carrera 3.2L coupe - departed - Stone Grey Metallic / Silk Grey |
UFLYICU
Re: H5 Headlight refresh (before & after pics)
That is actually a dessicant packet. Replace it or you'll be doing this cleanup job again soon.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
UFLYICU
I highly reccommend the "rejuvenated" H5's and Hella 450 flamethrowers tucked into the old fog holes. The combo turns night into day. (*Warning* - the Hellas are NOT street legal, they are for offroad use, but WOW!)
dmwallace, I just love them. No heat related problems, I pulled one lens recently to look and all seems 100%
very very nice at night. I have bad eyes and the improved lighting reduces my tension at speed at night. I copied Zonas on the Hella install driving lights and these things are ugly mean flamethrowers. I can not really use these driving lights around town. Just too strong. I originally put 100W H3 up from the Hella 55W and had to go back the 55W. I turned them on the rear of a stupidly reckless ricer car one night and they lit up the interior of his car like a police swat team helicopter... too funny They work very well but I will prolly go back to Carrera fogs.
"And there's no cure like travel to help you unravel the worries of living today. when the poor brain is cracking there's nothing like packing a suitcase ..(or getting in the Porsche) and sailing away " Cole Porter, anything Goes" |
I used Cibie 35's ( available as fogs or driving beam... I chose diving lights) instead of the Hella 450's used by Zoanas and others. The mounting for the Cibie is simplified...as it doesn't require the cut-'n-glue mounting mentioned in the Zoanas post
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Seeeu911:
Thanks very much for providing the feedback along with the original posting on the right steps to take. Looks like I will go down the same path...
Zoanas is right -- that little plastic thing is a moisture absorbant dessicant and should be renewed periodically. The assembly isn't airtight and it helps keep things reasonably dry in there for a while. I believe they're sold by our host.
Dan '87 911 Carrera - Cabriolet |
Dmwallace you are most welcome you will find Pelican essential! To the proper care and feeding of your 911.
There are other posts with great info on lamps etc. I recently bought some stuff from David Stern’s website. He has great tech info and while he appears to be the most factual, if not a little self serving, he is still just a vendor. The guys here will give you really good info, for the most part from practical experience not vendor opinions. Will, I like what I read about the fit of the Cibie's but only found them after I got the Hella's I am begining not to like either becasue I can not use the carrera fog plastic shroud around the lamp. I just like that look better.
UFLYICU
Wil, do you have a pic of the Cibie's on your car? I have plenty of opportunity to use my Hellas, and I really like their effectiveness on my sweet backroad night commute (I work shifts), but I also wish I could put them inside the fog housings to clean up the look.
I still have my old valance, and I've been thinking about modifying it for a cleaner looking driving light/airflow setup. For now, the Hellas are serving me (and the night critters) well.
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 01-13-2006 at 10:23 AM.. |
