Curious - Kill Switch?
So, picked up a 1984 Cabriolet and when looking through car found this red device. Wired to, I believe, the battery. I have not attempted to twist or remove to test my theory but wondering if anyone has seen this? Perhaps it’s a stock device on all these 3.2 models. Coming from an SC so new to me. Thanks in advance.
Titanium User
Not factory - just a ground disconnect. Maybe the car has a draw and battery would die after parked for a bit.
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
It's a standard battery disconnect switch like the ones you would find in a race car. You can turn it anti-clockwise and remove the red "key".
📸 https://www.instagram.com/porsche.tech 📸 |
Check that fresh air fan for a fuse. Fire hazard and later on Porsche started fusing them.
I would keep it, handy to shut off power when working on car or storing etc.. Good looking car btw!
RGruppe #180 So many cars.. so little time!! |
It's a 914 ...
One tip - don’t shut off the car while running using a simple disconnect like this. Depending on how it’s wired, it may not even stop a running engine. And if it removes the battery from the circuit, the alternator can cause a voltage spike and fry its own diodes.
Thank you
I greatly appreciate the input.
Burnin' Rubber
