1973 911 e hazard and turn signal issues
hi all. my 73 911 e hazards and turn signals went out. i checked all fuses and all are good.question is, is there a turn signal relay? i cant seem to find any. i did read theres one behind the fuel gauge in the dash. and also, my horn and back up lights arent working either!! im really getting tired of older cars. ready to sell them all and get a new gt3!
check under the dash (under the ignition on left)..there are 3 plugs -if one of them is unplugged
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
it is plugged into the firewall harness. i too it out and made sure it was fully seated. sounds like the relay could be behind the fuel gauge in the dash
just looked. its missing the relay. i pulled the turn signal relay from my 85 911. now i have all signals working!
PCA Member since 1988
How did the turn signals and hazards "went out"? If the relay was missing, they never should have worked in the first place.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
yeah its funny. my Porsche mechanic had the car for awhile, im thinknig it must have been missing after i dropped it off at his garage. i known him for a long time. not sure if he swapped it out, and never put it back in
