cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
G 50 trans fluid
Want to change the trans fluid in my 89 G50 Carrera as I have no idea if its ever been done before. What's the best fluid to use and how may qts?
Thanks,
Chris
89 G50 Carrera
73 911E
Old 09-25-2018, 08:07 AM
DWeg1998's Avatar
LSD or no?
I’ve tried Royal Purple, Mobil Delvac and Redline and I’ve had the best experience with Royal Purple. Easy to find too at your FLAPS
You fill it until it overflows. Around 3 bottles if I recall
Old 09-25-2018, 08:59 AM
cmcfaul's Avatar
Has LSD
What viscosity? Syn or other.
I did it on my 73 E with the 915. G50 is different.
Thanks,
Chris
Old 09-25-2018, 09:35 AM
gearhead
Use the factory fill Mobilube PTX.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-25-2018, 09:37 AM
DWeg1998's Avatar
75w-90 Synthetic is preferred by the consensus for G50
Old 09-25-2018, 09:59 AM
Spiderman
Jesse16's Avatar
I think its 3 or so quarts, any GL-5. I have used non-synth (likely what the factory used) Kendall that our host sells and synth from Brad Penn in the 75-90 weight. Only minor thing I noticed was the non-synth. was slightly slower feel when shifting from cold. I think you could use any Castrol, Valvo, Mobil product from your flaps and be fine. This is old school stuff. It is fine if you use LSD rated oil if you see it on the label. If your tranny has LSD, you need that rating.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 09-25-2018, 10:13 AM
Bill Verburg's Avatar
+1
unless you are tracking the car, then use Delvac
Bill Verburg
Old 09-25-2018, 10:43 AM
Unsafe at any speed
Nader's Avatar
Huh, did Swepco fall out of favor?
87 Carrera Coupe
Old 09-25-2018, 11:00 AM
Swepco is great for 915s still good but not as good for g50
Bill Verburg
Old 09-25-2018, 11:05 AM
Spiderman
Jesse16's Avatar
Maybe Swepco makes a GL-5 rated product. The 915 gearbox and G-50 are different. Hypoid gears maybe ??
Old 09-25-2018, 11:06 AM
After reading posts around here I recently switched to this - Kendall Super Three Star 75W-90
Sold: 1989 3.2 coupe, 112k miles
Old 09-25-2018, 11:48 AM
I have had just about everything in my G-50, even Swepco. I’m with Matt and Bill, go with what the factory and Porsche Motorsports use. Mobile
New shifter bushings also make a huge difference!
Old 09-25-2018, 12:03 PM
Apparently no longer available.
Wasn't original non synthetic? Should be go to a synthetic ?
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-25-2018, 12:16 PM
Unsafe at any speed
Nader's Avatar
I have an Alfa and Ferrari. People swear by Redline 75/90 NS for both. It's GL-5 as well.
For both transmission and diff in the Alfa, and transaxle in the Ferrari. They both have notoriously difficult 2nd gear shifting issues. How 'bout Porsche, any good there? I'd like to consolidate my fluids/lubricants collection (until I retrofit everything to electric drivetrains).
87 Carrera Coupe
Old 09-25-2018, 12:24 PM
I use motul 300 in my G50 and it is EXCELLENT. I believe you need the one with the LS additive(s).
https://www.motul.com/us/en-US/products/gear-300-ls-75w90
Old 09-25-2018, 12:38 PM
gearhead
https://www.*************.com/product/00004320420L.html
1974 914 Bumble Bee
2009 Outback XT
Last edited by Matt Monson; 09-25-2018 at 12:50 PM.. Reason: Sun Coast is *************
Old 09-25-2018, 12:49 PM
Northern Motorhead
wildcat077's Avatar
I use Mobil Delvac synthetic in both my G50 911 and my 944 race car with LSD ... been doing it for the last 7-8 years with good results !
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-25-2018, 01:01 PM
Here's some usefl data
Bill Verburg
Old 09-25-2018, 01:02 PM
Jacksonville, Fl
75W-90 Delvac +1
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 09-25-2018, 05:05 PM
That Guy
Techno Duck's Avatar
Redline 75w90 NS. If you have limited slip, add a little friction modifier.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-25-2018, 05:19 PM
