Small Leak at Oil Tank Hose
It looks like I have a small leak at the bottom of the oil tank where the rubber line connects. See pic below. Is there a fix for this short of replacing the whole line? Thanks!
Old 04-23-2023, 01:37 PM
proporsche's Avatar
if it is really small clean it once an while ..if it bad you could have it redone by local hydraulic shop.
But!! the problem could be if you would try to disconnect it from the oil thermostat unit the threads on the Aluminium thermo.could get striped.
So,clean it and see how it is..would my advice
ivan
1985 911 with original 501 587 miles...807 226 km
Old 04-23-2023, 01:45 PM
It seems very small. Just a little drop of oil, plus bottom part of hose looks saturated with oil. From your response, I’m assuming that the leak is probably at the hose crimp?? I’m going to take your advice, clean it and keep an eye on it. Don’t want to open a can of worms if I don’t need to. Thx.
Old 04-23-2023, 02:03 PM
proporsche's Avatar
yup
Old 04-23-2023, 02:19 PM
No immediate need but its going to need replacing sooner or later. I had the same problem with mine it was no big deal for me but expect to cut the nut on the thermostat side. Its better just to cut it off than risk stripping it out.
Old 04-23-2023, 02:20 PM
BoxsterGT's Avatar
Porsche Crest
Leaks do not fix themselves.
Replace it or Re-Hose it for the only real Fix.
I can help with the latter.
len.cummings @ verizon.net
Old 05-14-2023, 01:19 PM
Discseven's Avatar
I'd Brake Clean between the collar and hose all around and stuff the entire gap with 5 minute gel epoxy. (If it's a small leak now, chances are it will mature if left to do so.) Thing of 5 minute gel epoxy is something like $7. Worth a "test" as I see it.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-15-2023, 05:23 AM
