Dash E- brake light cluster? 3.2 Carrera
Hi Gang
I was trying to remove the top left bulb in the E brake, brake pad, seatbelt light cluster and broke it Now I cant get it out and have read it may be all one soldered unit? Do i need to replace that cluster or just remove from the rear? AND i was removing that light cause it kept telling me my E Brake was on - but intermittent- when it wasnt My alternator is great. Any other ideas about why that light would come one now and then. Like mid drive along the highway? Thanks!! |
This bulb is indeed soldered. Get a new bulb and solder it onto the PCB.
Also, this bulb may go on when brake fluid is getting low. You may want to check this too. Also an interesting topic about this module here. |
