high beams out
high beams don't flash unless the light are on and now my blinkers have blown fuse is it in the blinker switch on the column? and how to test out thanks
Old 05-22-2023, 06:30 AM
What year car would be a good place to start. Could be a variety of issues. Start by getting the wiring diagram for your car and a decent multi meter.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-22-2023, 08:30 AM
al lkosmal's Avatar
Searching the forum is a good place to start.
The headlight switch is a typical failure point.....you might find the answer to your problem here.
turn signal switch quick fix pictures
RGruppe #669
http://www.x-faktory.com/
Old 05-22-2023, 09:11 AM
I had to bend the metal high beam contacts on the switch. Immediately after that I installed relay kit for the lights and high beams.
Old 05-22-2023, 12:32 PM
high beams
008 can youi expand some on the clips are they on the blinker lever under the steering wheel thanks
Old 05-22-2023, 02:20 PM
thanks for the link lots of good info there
Old 05-22-2023, 02:39 PM
I had to remove the steering cowl, then you can see there are 2 copper "levers" one moves and goes against the other when the high beams are on. mine had to be bent a little to make good contact. I used the post above way back to fix my high beam issue. No problem with my directionals though.
The big thing is all the amps and volts for the lights go through that switch.
BUT before you start tearing things apart what year is the car because testing the basic wiring first is better to make sure the wiring is all good. Did it work before and just start acting up? was any work done? is the fuse the correct amp?
Once you get the wiring or switch fixed install some relays. I even have h4 bulbed lenses now that I can run higher watt lights.
Old 05-22-2023, 05:33 PM
