How to repair hole in rear left side passenger well.
1988 3.2 Coupe. I ripped out the rear interior to do a RS carpet and I found that the rear passenger seat pad and interior was wet mush. I am assuming that it has been this way for ages (I am the second owner) and just ate up the galvanizing and rusted through. Testing with a screw driver shows everything else is solid. Any ideas on how to fix this? Should I get a piece out of a wrecked Carrera? Who has stuff like that? Fab something out of pieces? JB weld!? thanks
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 05-20-2023, 09:23 PM
Bland
unclebilly's Avatar
Restoration Design $285.
https://www.restoration-design.com/store/product/PP222L
Old 05-21-2023, 03:46 AM
Cut back to clean / undamaged metal when doing the repair.
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 05-21-2023, 05:53 AM
PCA Member since 1988
Ahhhh, the old leaking rear window gasket cancer. I would just cut and hammer a replacement piece to fit, if that's the only spot. If it's more extensive, then buy the replacement panel. The package shelf probably looks like Swiss cheese too.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-21-2023, 05:27 PM
Still here
pmax's Avatar
That's curiously not at the lowest spot, do you park on a slope ?
Old 05-21-2023, 07:30 PM
Send a message via ICQ to AirJose
repair hole
You will need a welder anyway,
1. Cut a nice L shape piece of metal and form it to match the curvature on the area.
2. Place it in top of the damages area and cut the damaged area with a Dremel or small gigsaw.
3. Use a magnet or Clecos to hold the metal and weld around.
4. Grind excess metal and make it pretty!
Good luck,
Jose
Old 05-22-2023, 02:47 PM
