| JWest |
05-29-2023 02:44 PM |
Originally Posted by ramonesfreak
(Post 12007578)
Yea it’s nice.
About the clamp, any one handed clamp that is supposedly easier to adjust with one hand….my observation is that they are actually more difficult to get the adjustment perfect because you no longer have the counter force from opposing wrenches. Instead you gotta hold the rod in place by holding the shift knob against the force of the one wrench tightening the clamp…not easy or precise. A bit of a scam the way they are promoted. Noticed it immediately and it pissed me off
Interesting. The way I adjust is to hold the shift knob and tighten the coupler, and I designed the one-handed clamp to assist my preferred method. Before the one-handed clamp, I had to awkwardly use one hand on both wrenches to tighten enough to hold the adjustment, then complete the tightening of the nut and bolt with two hands.
I find holding the knob allows for great precision in positioning, since you have distance and leverage to work with. For me, it is a huge time saver and I do a lot of installs and readjustments.
I'm sorry your experience was less than satisfactory and you considered it a downgrade. You could drill through the threads and put a nut on the end with a longer bolt and still have an upgrade from the original (that was probably bent and scarred).
James
