1979 911 SC - timing chains
I have my 911 SC in pieces changing valve guides and piston rings.
Should I change the timing chains? The mileage on the chains is uncertain, but they look to be in good shape. Also, what is the opinion on using the ones for sale on Pelican with the the master link?
Many thanks.
Old 05-26-2023, 06:13 AM
you left out how many miles are on your motor.
1976 914
1986 951
Old 05-26-2023, 06:14 AM
There is 130K on the engine, but no history a if the timing chains have been replaced during that mileage
Old 05-26-2023, 06:26 AM
Change them.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-26-2023, 06:45 AM
Look at changing sprockets too - they may be worn.
Old 05-26-2023, 06:50 AM
I would also consider adding Carrera chain tensioners, if it doesn't already have them.
Roger
1984 911 Carrera coupe
1972 911T coupe (owned 1978-1995, sold after divorce. . . . bummer)
Old 05-26-2023, 09:25 AM
How much of an issue would it be if I did not change the sprockets on the IMS, and just did the ones up top?
Old 05-26-2023, 09:26 AM
