Reinstalling aluminum trim to rear side window
Is there some secret to getting this back on?
![]() Last edited by Kansas; 05-30-2023 at 07:51 PM.. |
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!! |
Have to put trim on before install.
So, remove the window and put the trim on and reinstall. Won't happen with the window on the car. A pain, unfortunately, maybe take it to a glass shop.
If you have access to PCA, Panorama Magazine issue #791 has a good ‘hands-on’ article regarding Replacing Window Seals that goes thru the steps for removal/install including trim. Yes, window has to be removed.
Why can’t I just insert it into the seam. I’ve been able to get some of it to insert. Just need an extra set of hands. No way in hell am I removing the window myself. I’d have a glass guy do it if it comes to that.
Because you can't, that's all. Same with the front and rear glass. Maybe do a Youtube video of how you're gonna do it so the rest of us 911 guys will know the trick? No fair cutting the rubber.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 05-31-2023 at 05:27 PM.. |
yup window out. I went to reinstall my rear glass with the new seal and trim... trim popped out had to take the window fully out again. giving myself a day before I go back to it... wasn't a good day wrenching on the 911. Good luck.
PCA Member since 1988
Well, technically you could install the trim with the window already in place, but you will mangle the trim in the process. Take the window back out. It ain't nearly as hard as a front or rear windshield.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
