Reinstalling aluminum trim to rear side window
Is there some secret to getting this back on?
Old 05-30-2023, 08:47 PM
Reinstalling fixed rear quarter window -- tricks or tips?
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 05-31-2023, 05:00 AM
Have to put trim on before install.
Old 05-31-2023, 05:01 AM
The rear window was never removed. Just the trim. I need to insert the trim back into the rubber seams, but can't. What about using some kind of lubricant so that the trim inserts easier?
Old 05-31-2023, 09:29 AM
The window was never removed, just the trim. I need to get the trim back on ASAP! It looks awful. *
Old 05-31-2023, 09:33 AM
So, remove the window and put the trim on and reinstall. Won't happen with the window on the car. A pain, unfortunately, maybe take it to a glass shop.
206 637 4071
Old 05-31-2023, 10:09 AM
If you have access to PCA, Panorama Magazine issue #791 has a good ‘hands-on’ article regarding Replacing Window Seals that goes thru the steps for removal/install including trim. Yes, window has to be removed.
Old 05-31-2023, 01:05 PM
Why can’t I just insert it into the seam. I’ve been able to get some of it to insert. Just need an extra set of hands. No way in hell am I removing the window myself. I’d have a glass guy do it if it comes to that.
Old 05-31-2023, 05:50 PM
Because you can't, that's all. Same with the front and rear glass. Maybe do a Youtube video of how you're gonna do it so the rest of us 911 guys will know the trick? No fair cutting the rubber.
206 637 4071
Old 05-31-2023, 05:58 PM
yup window out. I went to reinstall my rear glass with the new seal and trim... trim popped out had to take the window fully out again. giving myself a day before I go back to it... wasn't a good day wrenching on the 911. Good luck.
Old 05-31-2023, 07:43 PM
PCA Member since 1988
Well, technically you could install the trim with the window already in place, but you will mangle the trim in the process. Take the window back out. It ain't nearly as hard as a front or rear windshield.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-01-2023, 02:29 PM
