Test Results……….
Thomas,
Within an hour after your package arrived at my doorstep, I was able to complete the tests. I usually do the test within a day but never within an hour. Anyway, here are the test results: TTV………..Defective and leaking. It should be closed at room temp. and could not hold a vacuum reading at all. No good. WUR-045……………the CCP @ 68°F is within spec. , WCP without vac @ 40 psi. is within spec. and WCP with vacuum @ 48 psi. is out of spec. However, the WUR is still capable of starting and running your motor. While it is out of spec, it is not defective but would need some work to get the WCP set correctly. Tony Edited: There was a typo. 32°F originally written was edited to 68°F. See above. Last edited by boyt911sc; 06-27-2023 at 01:49 PM.. |
1978 911SC |
I just received the WUR. Very pretty. Wasn’t expecting the extra touches. Well done, and Thank you.
I installed it back in the car with the TTV. My garage is a heinous Texas 88° right now per the infrared thermometer directed to the WUR housing. -System pressure reads 4.8 (4.5-5.2) -Cold ctl pressure reads low at 2.1 (2.4-2.85) per Bentley chart. I did not plug in the WUR power connector to test warm yet. I thought I would check with you before tweaking the new CCP screw. tw Quote:
1978 911SC |
Start Up……….
Thomas,
The CCP was set lower and that was intentional. Install the WUR as received and test run the FP for several seconds and check for any sign of fuel leak. Start the motor and record the control pressures readings until CCP stabilizes to WCP. Please take note how many attempts before you get the motor to start and idle. If your motor is having trouble starting, do not blame the WUR. We got other problem to identify this time. Keep us posted. Thanks. Tony |
Ok…
-System pressure reads 4.8 (4.5-5.2) -Cold ctl pressure reads 2.1 (2.4-2.85) -Warm ctl pressure (ENG off, FP running, power plug installed) in one and a half minutes, it creeps up to 2.75. Once it settled, I hit the starter, it jumps IMMEDIATELY to 3.5 Once the WUR was electrically warm, I started the car. It took at least a half dozen + starter attempts to get it to even try to stay running on its own. The car doesn’t want to idle smoothly and idles very roughly around 500rpm, dying several times. All of this with the gauge still installed. Quote:
1978 911SC |
Wrong Start Up Procedure……..
Thomas, You are doing it all wrong. Both the WUR and the engine should start at the same ambient temperature. What you did was heat up the WUR and got the CCP to WCP and started the cold motor. WRONG! You had a cold motor with fully warmed up WUR with 52 psi. and you expected it to START? What were you thinking? Let everything cool down and try again. When was the last time you had the motor running? Do you have an inductive timing light? Have you checked for vacuum leaks? It is critical that you don’t have any significant source of unmetered air going into the system. They all leak it is a matter how much leak your system could tolerate to affect ignition. Try it again after an hour or two. Thanks. Tony |
Yep, I wondered about that, and it makes complete sense. I was mentally in ‘lab’ test mode and not being very real world. Lol.
The motor (car) hasn’t been on the road in a couple of months because of these issues, but prior I had put several hundred miles on it. Yes on a timing light. Have not checked timing on this car. As far as unmetered air, when it was last running (in the garage) a few weeks ago, warm and idling, I opened the oil cap and the rpms dropped significantly. I took that as a sign that I didn’t have a catastrophic vacuum leak. I’ll fire it up in a couple of hours and see how she does. Thanks for the input! Quote:
1978 911SC |
Defective TTV……….
Thomas,
Did you install a new TTV? Your old TTV is leaking and don’t use it. Tony |
I am going to log the pressures from cold, but it will be Thurs/Fri before I can do that.
In the meantime… I did let it cool about an hour and restarted it, and the fast idle came up (1750ish?) and it was smooth. As it started to warm up, the idle began to ease downward, and the fuel pressure easing upward. Then suddenly, after 20-30 secs or so, the idle suddenly plummets (500ish + drop?) and the fuel pressure slams to 3.5. It begins stumbling into a spiral of death. This is puzzling me. Quote:
1978 911SC |
Yes new OEM Porsche TTV is installed.
1978 911SC |
CIS Troubleshooting……….
Thomas,
We will need to test the integrity of your vacuum system. A smoke generator is a very effective tool to locate the hard to find leak sources in your CIS motor. Leave the CIS gauge installed for the meantime and you could drive the car with it installed. Just make sure you secure it away from the alternator fan belt. Something is not right. Tony |
While I wait…. if there was a significant vacuum leak, wouldn’t the effect be more linearly present throughout the entire startup vs a dramatic stair-step change as it approached operating temp? What leaking components would likely cause that sudden dramatic change in fuel pressure?
1978 911SC |
Does anyone have any input as to why the Cold fuel pressure (2.1 bar), upon starting the car, starts to slowly increase, and after a few seconds snaps to 3.5 bar?
Also something else I noticed… I read 13.5v at the battery. I get only 11.5v at the WUR connector with IGN ON and FP running (engine OFF) When I start the engine, it goes up to 12v plus a little. Not sure what this means.
1978 911SC Last edited by twaldron; 07-04-2023 at 02:10 PM.. |
PCA Member since 1988
You should read the same voltage at the WUR connector as at the appropriate pin on the 14 pin connector (should be pin 10). If it reads lower, you have a poor connection somewhere. And that pin should also read normal system voltage.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 07-04-2023 at 03:48 PM.. |
What 14 pin connector are you referring to?
1978 911SC Last edited by twaldron; 07-04-2023 at 04:23 PM.. |
The fuel distributor has a fuel "system pressure" regulator on the back of it. That's what sets the approx 5 bar SP. I don't see how it would cause a "snap" from a lower CP to a higher CP, but I'm trying to think of something other than the WUR that might be implicated.
Maybe your gauge is hanging and then releasing? Let's wait and see if Tony has seen that previously.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 07-04-2023 at 11:07 PM.. |
The system pressure has been a solid 4.8 and the needle never pops when the gauge set is in system pressure mode. When I open the valve into CP mode, as the WUR bimetal strip warms with engine running between 2.1 and say 2.3 then snaps to 3.5, the needle stays rock solid at 3.5 as the engine slowly dies. If I warm the WUR with only the WUR power cable (no engine running) it only gets to 2.75 and the gauge never pops. Whether the needle pop has anything to do with the motor dying, I don’t know. I just know it’s not supposed to do it.
1978 911SC Last edited by twaldron; 07-05-2023 at 12:55 AM.. |
Thomas, Based from the data you provided above, the fuel pressure readings are NORMAL. What was the ambient temperature in your garage? These are your collected data: SP = 4.8 bar (70 psi.) CCP = 2.1 bar (30 psi.) WCP (no vac) = 2.75 bar (40 psi.) WCP (with vac) = 3.5 bar (51 psi.) The popping noise you have observed was probably the TTV opening after starting the motor (delayed opening). If your motor is starting and stalling after the initial start, do not blame the WUR. There is something wrong with your CIS and you need to investigate the culprit/s. They could be unmetered air or the fuel mixture. Test and confirm. Tony Last edited by boyt911sc; 07-05-2023 at 05:01 AM.. |
Moving on to the next stage of testing, looking at vacuum leaks. Must be a big one or a combination of things because the engine won’t run. Thank you for your input.
1978 911SC Last edited by twaldron; 07-05-2023 at 05:33 AM.. |
Supplemental Tests……….
Thomas, If you disable the TTV by unplugging the electrical plug, the cold motor would start and run a bit longer but would stall later(?). With the CIS pressure gauge installed, observe at what control pressure the motor would stop running. Keep us posted. Thanks. NOTE: You should not have a cold control pressure spike during this test. Tony Last edited by boyt911sc; 07-05-2023 at 10:33 AM.. |
