-   -   Squirters replacements (http://forums.pelicanparts.com/porsche-911-technical-forum/1140890-squirters-replacements.html)
avorkinn 06-01-2023 05:14 AM
Hi,
I am replacing the oil squirters on a 2.7 engine with magnesium crankcase. Until now, I have only done this on aluminum engines and in addition to Loctite I have treated the edges of the hole to block for the squirters to come out. On the magnesium crankcase I find that impossible, the metal only breaks off. Before I removed the old ones, I could not see that it had been done from the factory either.
Any experience, what did you do?
Dpmulvan 06-01-2023 07:17 AM
1.Use oversized squirters and loctite 620 retaining compound.
2. Use threaded squirters
3. Install threaded plugs and redrill.
avorkinn 06-01-2023 07:43 AM
Hi,
I have already put them in with Loctite 638, I presume that will work?
