RLJ RLJ is offline
Senior Registered User
She is whole again !
After two and a half years, bent and crashed race cars, a fire in one, several blown motors and trannys my friend and local Porache wizard has my motor done. Again. Iris is back in my garage with the engine and tranny back in.
Removing the PMO's adding fuel injection and 1 5/8" headers she now makes 298 HP and 248 ft/lbs. torque, HP is at 6700 RPM and the torque is about 6000 RPM. Most of the mapping was done on the crankshaft dyno but I am sure there will be some "on the street" tuning to be done.
Now I get to mount the brain, mount the air/fuel meter, put the old high presure fuel pump back on and the high pressure filter, re-run most of the engine wiring and then "go for a ride".
Randy Jones
1971 911 Iris the Slut rides again !
Old 11-20-2005, 02:18 PM
Driving member
jester911's Avatar
That looks great. Let's see the rest of the car.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-20-2005, 02:41 PM
Scuba's Avatar
Uh oh, I just switched my new paint color choice (that goes on next weekend) from a non-Porsche royal blue metallic to the original Arctic Silver...I have a feeling I may have to make a phone call once these pics are up.
Scuba
Old 11-20-2005, 02:46 PM
RLJ RLJ is offline
Old pics of an old girl
Gee........I'll show ya' my car.
Above photo by Mr. Sherwood Lee, thank you sir.
Randy Jones
Old 11-20-2005, 04:28 PM
Jeff Alton's Avatar
Details on the motor please. What ITB are you using and what controller? Displacement, CR, cam and exhuast info would be great.
Fabulous looking car!
Cheers
www.turn3autosport.com
Old 11-20-2005, 05:13 PM
randywebb's Avatar
Randy --
You had about 250 hp before, right? So you added about 50 hp? How's the torque feel at the low end and mid-range?
Congrats!
-- Randy
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-20-2005, 05:16 PM
rdane's Avatar
Congrads Randy...very cool car!
Specs from earlier post/posts by RLJ
"46mm PMO, carbed 3.2 short stroke. with dual plugs, Iris:
281 H.P./ 244 ft./lbs. torque at the flywheel at 6700 RPM's.
Changed muffler and put her on the DynoJet to rejet the carbs and this is what we received. S-CAR-GO Racing dual in/out stainless steel muffler change and we received 222.1 HP and 201.5 ft/lbs. torque measured at the rear wheels at 6500 RPM's"
Old 11-20-2005, 05:30 PM
RLJ RLJ is offline
Spec. sheet
I don't have the motor plugged in yet, a winters worth of work I think ?
Here is some basic info, engine work by Dick Elverud of Portland Oregon. 3.2 Liter (98mmX70.4mm), 10.2:1 J-E pistons, Web-Cam's 120-104, 3.2 Carrera heads dual plugged, 964 dizzy custom built with mechanical advance, ARP rod bolts, Vellios throttle bodies and Simple Digital Systems fuel management system, 1 5/8" George's headers ceramic coated, S-Car-Racing dual in dual out stainless steel muffler, Elverude custom aluminum flywheel and Sach aluminum pressure plate, Carrera tens, dual MSD-6AL ignition boxes, 930 lower valve covers.
Horsepower as I said is 298 at about 6700 RPM's and torque is 248 ft /lbs at about 6500 RPM.
Old 11-20-2005, 06:52 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
That blue is stellar, what is the original paint code?
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-20-2005, 07:08 PM
Banned but not out, yet..
RSBob's Avatar
Randy, that car is positively OUTSTANDING, with the grunt to back up the looks. I will look foward to seeing it at the next meet. Did you fab your own RS America panel for the back or....? Congrats on putting together such a fine machine. Ferry would be proud - if not shocked.
Old 11-20-2005, 09:33 PM
Bird. It's the word...
Fishcop's Avatar
Hey Buddy
Great to hear you've got the "Slut" back!
You're going to thrill a whole 'nother generation of Pelicans with Iris... it's been too long.
"Iris" aka "The Slut" is "Iris Blau" a 993 colour.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 11-20-2005, 11:51 PM
adomakin's Avatar
Hi Randy, superb looking car. Great to see that you went for the SDS efi. I'll be running that system on my 3.3t. how have you found it? easy to install/understand/program?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-21-2005, 12:51 AM
Absolutely spectacular....congrats!
Yasin
Old 11-21-2005, 07:16 AM
I would rather be driving
jpnovak's Avatar
For those who do not remember Iris' debut. There are a few specs in here.
Iris's Measurements
Old 11-21-2005, 07:48 AM
450knotOffice's Avatar
Wow! That car is just beautiful! Almost 300 horsepower puts you right in 996 territory without all of the weight. Your car must simply fly.
Nice backdrop for the pics btw.
Old 11-21-2005, 08:45 AM
wru wru is offline
Iris rev 2
Long overdue follow up here picking up where Randy left off 18 years ago. I became the custodian of Iris in 2018, and drove it as-is for a year. By 2019 i was sleuthing for details about the prior build and even posted here looking for anyone with info. She's a monster as is and my intent was to go about refreshing while keeping the essence of what Randy built as the basis...
Since acquiring,
- dropped the motor and installed a Patrick Motorsports LW flywheel and new Sachs clutch.
- left the motor and gearbox alone save a leakdown test and...
- all new accessible seals and clutch shaft bushings/guide tube while everything was out
- new motor and trans mounts
- New high torque starter (she decided to eat the pinion on the original Bosch starter while on a Hill Country Rallye in 2020)
- New proper MSD high vibration coils (black vs. red) were swapped to keep the outlaw upside down mounting position.
- The fine gentlemen at Mayo's tuned the motor and cleaned up the carbs.
- Full suspension was removed, everything blasted and fresh powder coat
- Rebel Racing teflon front and rear bushings added
- Rebel rear RSR monoballs.
- Tarrett rear RSR replica swaybar mounted on new brackets
- Tarrett RSR replica front swaybar and drop links
- New monoball upper strut mounts/camber plates
- Rebel aluminum front strut bar
- New Bilsteins front and rear (HD and Sport)
- Elephant quick change spring plates
- Sway A Ways 22/27
- Rebuilt rear axle CVs
- Brakes calipers redone by PMB front and rear
- New Sebro rotors
- New parking brakes
- Replaced the Seine shifter with a Numeric short throw shifter
- Cleaned up and resprayed the engine bay while it was out, redid all the electronics out back.
- refurbed heater boxes in anticipation of eventually adding back heat.
- Interior was completely stripped, rear shelf removed along with all the audio bits (save the door cards)
- dynomat'd the floor and rear, recarpeted with RS Lightweight carpet (dynomat was a onene weight swap for all the audio stuff and shelf)
- redid the pedal cluster
- New GTS Classic Hockenheim seats with Scheel style headrests
- New Avon CR6ZZ's in 185 and 215
- fresh corner balance and setup by the Mayo's crew, along with countless other consults. If you are in TX, these gentlemen are your proper counsel.
and a million other misc bits that I'm forgetting.
Many thanks to all those i've pestered for info, insight, and education. have had the good fortune to come to know many in this small community that have helped tremendously, and hope to pass along the same.
anyway... Iris rides again. Some photos of various points along the way;
Old 06-05-2023, 03:28 PM
Beautiful car - color, stance, everything!
Roger
1984 911 Carrera coupe
1972 911T coupe (owned 1978-1995, sold after divorce. . . . bummer)
Old 06-06-2023, 12:04 PM
