Try not, Do or Do not
Henry Schmidt's Avatar
How clean is your oil?
Originally Posted by gled49 View Post
In post #5 what is the oil filter used with the 993 console?
After posting the answer to this question, I decided to do some serious investigating.
Although our original filters had some very impressive specifications, with some additional investigating and with some in-depth conversations about oil flow and particle retention, we were able to have Hubb supply us with a far superior filtration system. We are working closely with Hubb engineers to make a racing version of their filter available to the Porsche community.
Although these filters will be/are DYI serviceable, in the near future we hope to offer an in-house sonic cleaning service that will restore the filter to 99% of it's original flow specifications.
Hubb Filtration Systems
Filter Specifications
• Filter-in-a-filter design that is 99% efficient at removing oil contaminants at 25 microns
(versus 52% for conventional filters)
• Two pressure differential valves for increased oil flow and engine safety
• Filter is made of surgical stainless 316L weave and is cased with a hardened aluminum
shell.
• All internal parts are easy to clean and re-usable
• Entire filter is completely recyclable – no waste
• Filter can be drained 100% of oil – does not capture and hold oil in filter like paper filters
(approximately 5 ounces per filter)
• Improve oil flow by up to 5 times, when compared to conventional filters, to reduce
engine friction
• Produce an oil flow rate of up to 50 gallons/minute, compared to 10-12 gallons/minute
• Require only .2 PSI/gallon to push oil flow, compared to 7 PSI/gallon for conventional
filters
• Increase contaminant storage capacity by 5 times, but do not accumulate unrecyclable
oil like conventional filters
• Reduce carbon monoxide emissions by up to 30% and nitric oxide emissions by up to
16%
• Double your standard oil change interval reducing oil costs by 50% or more
• Ability to have Hubb clean the filters and manage your filter core inventory for you
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-05-2023, 05:55 AM
Following
Old 06-05-2023, 06:17 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
Subscribed
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 06-05-2023, 06:18 AM
