-   -   Custom Rear 930 Hats and Rotors (http://forums.pelicanparts.com/porsche-911-technical-forum/1141377-custom-rear-930-hats-rotors.html)
winders 06-09-2023 11:18 AM
Well, after many years searching for a better rear rotor solution for my race car with 930 trailing arms, I gave up had a custom aluminum hat and rotor built by the folks at Coleman Racing Products.
http://forums.pelicanparts.com/uploa...1686334541.JPG
This setup is 4.2 lbs lighter per side than the stock rotors and does not support the parking brake. I had to remove some material (a tab) from the trailing arm bit that did not affect the integrity of the trailing arm.
Billiam 911 2.8 06-09-2023 01:05 PM
Great looking rotors, Scott. What kind of life do you expect from them? Saving 8.4 lbs. of unsprung weight is significant.
winders 06-09-2023 02:15 PM
I expect the slotted rotors to last at least one full race season. They will be less likely to crack than the stock 930 drilled rotors. Not only is that weight unsprung, it is spinning too.
Cory M 06-09-2023 02:40 PM
Very nice. I had custom Coleman rotors on my race car and they were good. About half the price of the factory Porsche parts and they lasted much longer since they weren't crossed drilled.
