-   -   Inner and Outer shift coupler boot fitment (http://forums.pelicanparts.com/porsche-911-technical-forum/1141880-inner-outer-shift-coupler-boot-fitment.html)
generalsmirnov 06-17-2023 11:32 PM
Hi,
Do the inner and outer shift coupler boots fit together in some way, or just kind of push against each other? The outer boot is tight around the tunnel flange, but the inner seems to just flop around. Do people even bother with the inner boot?
Thanks,
Scotthttp://forums.pelicanparts.com/uploa...1687070016.jpg
Ian Comerford 06-18-2023 12:02 AM
I used a cable tie to hold the inner in place, the boot fits over the round section in your picture
eflight 06-18-2023 03:53 AM
I tried for hours to make that inner boat go over the outer boot with no luck
Is there a secret method to make that happen, or is do I just need smaller hands?
manbridge 74 06-18-2023 06:26 AM
You just need a little soap to use as lube and it will go right on. Soap then dries allowing a tight fit. Parts catalog does not show a clamp last I looked.
EC900 06-18-2023 07:35 AM
That’s a clean tunnel.
I recently replaced all bushings and there was neither an inner or outer boot (PO replaced coupler) but a zip tie that once held them together was laying in there. I didn’t bother to put a new inner boot on.
To me I think the outer is more important, surprising amount of air, plus dirt and maybe even exhaust that comes through that opening, also another pathway for seasonal critters.
If boots are real stiff, warm up the rubber with a hairdryer or soak in hot water to make inner boot more pliable and use soap or silicone paste.
generalsmirnov 06-18-2023 10:30 PM
Thank you everyone, I'll give the soap+heat trick a go.
PeteKz 06-18-2023 10:40 PM
Get the bottom edge on first, then use right-angle needle nose pliers, or hook, or similar curved tool to pull the side and top of the boot over the section. I didn't have any trouble with that, and I have large hands.
generalsmirnov 07-10-2023 04:42 AM
Thanks for all your advice. Some warm, soapy water and a bit of light pliers action did the trick.
http://forums.pelicanparts.com/uploa...1688989321.jpg
canamfan 07-10-2023 08:19 AM
Zip/cable tie that thing before it slips off again or you'll be doing it all over again ;)
