Inner and Outer shift coupler boot fitment
Hi,
Do the inner and outer shift coupler boots fit together in some way, or just kind of push against each other? The outer boot is tight around the tunnel flange, but the inner seems to just flop around. Do people even bother with the inner boot? Thanks, Scott
I used a cable tie to hold the inner in place, the boot fits over the round section in your picture
Is there a secret method to make that happen, or is do I just need smaller hands? |
Functionista
You just need a little soap to use as lube and it will go right on. Soap then dries allowing a tight fit. Parts catalog does not show a clamp last I looked.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
That’s a clean tunnel.
I recently replaced all bushings and there was neither an inner or outer boot (PO replaced coupler) but a zip tie that once held them together was laying in there. I didn’t bother to put a new inner boot on. To me I think the outer is more important, surprising amount of air, plus dirt and maybe even exhaust that comes through that opening, also another pathway for seasonal critters. If boots are real stiff, warm up the rubber with a hairdryer or soak in hot water to make inner boot more pliable and use soap or silicone paste. |
Thank you everyone, I'll give the soap+heat trick a go.
PCA Member since 1988
Get the bottom edge on first, then use right-angle needle nose pliers, or hook, or similar curved tool to pull the side and top of the boot over the section. I didn't have any trouble with that, and I have large hands.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thanks for all your advice. Some warm, soapy water and a bit of light pliers action did the trick.
'82 SC TL
Zip/cable tie that thing before it slips off again or you'll be doing it all over again
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
