-   -   What not to do when building an engine. (http://forums.pelicanparts.com/porsche-911-technical-forum/1142039-what-not-do-when-building-engine.html)
yelcab1 06-21-2023 05:31 AM
My customer bought an engine 3.6L built with RSR cams. It froze up 3000 miles later and he brought it to me to tell him what went wrong.
Too much silicone being used everywhere.
http://forums.pelicanparts.com/uploa...1687353915.JPG
Note the excessive use of black silicone filling up the rocker shaft holes making it impossible to now remove the rockers.
Bit of silicone broke off blocking oil passages leading to oil starvation which spun the number 3 rod bearing and likely bent the crank.
http://forums.pelicanparts.com/uploa...1687354037.JPG
Whoever did this had no business building engine.
walt 06-21-2023 05:38 AM
When you think you have seen it all.
Damon88 06-21-2023 06:22 AM
Looks similar to the "NEW REBUILT" engine I purchased from forum member couple months back.. Everyone claims to be engine builder these days... great picture showing what not to do. Crazy.
David Inc. 06-21-2023 06:26 AM
Where does the mindset of using silicone everywhere come from? Do people just naturally assume since they used silicone caulk on their shower that they should use it in other places for sealing?
Those rocker shafts make me want to puke.
al lkosmal 06-21-2023 07:22 AM
rebuilt engine
Seems to be going around.....here's some pix of the rockers on a 3.0 that was sent to me to figure out why it was making bad, banging noises......
The 1st pic shows the same use of silicone to seal the rockers.....will be a beeeyatch to get those out of there......also some sticks/sawdust stuck to the gasket......but the 2nd pic shows the winner....pistons installed rotated 180 degrees out. Pretty sure that is the cause of the bad noises.....
http://forums.pelicanparts.com/uploa...1687360514.jpg
Nditiz1 06-21-2023 07:26 AM
Yep same wonkiness going on with this 3.0. Besides loving red RTV and using lower allen bolts instead of studs I just uncovered this:
http://forums.pelicanparts.com/uploa...1687361109.jpg
proporsche 06-21-2023 07:45 AM
we have some schmucks here in Czech too;-)http://forums.pelicanparts.com/uploa...1687362100.jpg
proporsche 06-21-2023 07:52 AM
here some genius helped himself with a stretched chains...welded some extra on the arms to cover the space...oh ya the chain was rubbing on top a little..That was 911 imported from over the pond.....
Ivan
[IMG]https://zupimages.net/up/23/25/j5mj.jpg[/IMG]
IndyAlex 06-21-2023 08:08 AM
Woooooooooooooow.
Matt Monson 06-21-2023 08:54 AM
Seen that waaaaay too many times over the years.
2.7RS 06-21-2023 09:30 AM
Top Dollar
One of Kind
Unobtainable
They don't make them anymore.
You won't find another one this condition
Has all the paperwork
Blah Blah Blah. I feel sorry for your customer.
tsuter 06-21-2023 10:07 AM
Its these peeps think they can R&R rocker shaft seals with the engine in the car...and then they give up and stuff the rocker shaft recesses with silicone.....
Nditiz1 06-21-2023 10:40 AM
I have added them with engine in situ. It can be done correctly.
theiceman 06-21-2023 11:19 AM
for the record i replaced all my rocker shafts with the engine still in the car. I had the exhaust off to upgrade to SSI anyway . Upper back couple were finicky , bot other than that, not too bad.
pmax 06-21-2023 11:32 AM
Yeah, I hear you.
Wasn't that a well known pro shop as well ?
PeteKz 06-21-2023 01:20 PM
Likewise here. I did it a few months ago with the engine in the car, and it was a PITA to get those suckers back in with the RSR seals on them, but a couple thousand miles later, they aren't leaking, so I must have done something right.
Damon88 06-21-2023 01:41 PM
Originally Posted by pmax (Post 12028219)
Yeah, I hear you.
Yes it was... insert face palm here...hah
fanaudical 06-21-2023 07:48 PM
Wow...
I'll admit that I've rebuilt only two auto engines (one a 327 Chevy and the other my 2.7). Each was a very different animal. In both cases I did a ton of research and reading first to understand what to do (and more importantly what NOT to do). Lots of great info here and in many books related to proper sealing and assembly of 911 engines. There is no excuse for what is seen in those photos...
ant7 06-22-2023 05:10 AM
As a former mechanic, and engine builder, looking at this I despair;:mad: and how much I wonder was the over-all cost of this experience ??? :confused:
dannobee 06-22-2023 06:36 AM
Holy hell, when I saw the late model cams with the early big nut and washer with a bolt and spacer, I have to think that the guy never even bothered to look up the prices of the parts to do the job right. For about $30 he could have done it the right way.
