Permatune CDI Box - Fixable?
I had this cdi in a 1983 SC when suddenly it quit working
the little green light blinks slowly and as per the label on the unit that means it's good but it's not. it doesn't work. i swapped it out for another one and the car started immediately. put this one back and nothing. So the question is - are these things fixable? or does it go in the trash? ![]()
IG @Drola964 1973 BMW 2002 1990 964 C2 2007 GT3 2014 Ram 2500 Cummins |
Fixable — Yes
Also upgradeable, if you want to keep an original looking box. Some internet sleuthing will give you lots of options. I believe that Perma-Tune still exists and can repair them. Even if you don’t repair it, it’s worth something to somebody as a core. Sent from my iPhone using Tapatalk |
Really? You do see that the electronics have been potted, and as such the electronics are destroyed when the potting is removed.
Do a search about the high failure rate of this CDI!
Dave |
The Blue Permatune that came on my car has been repaired, a long time ago and I don’t recall the details but I’m thinking it went to permatune.
Doesn’t classic retro put new guts into old boxes - or is their service limited to Bosch boxes? Sent from my iPhone using Tapatalk |
https://permatune.com/technical-information/ Not potted boxes are repairable, pottet boxes probably as well, never tried yet. But there are some videos on youtube showing to uncover potted electronics (no permatune boxes). On of the main reasons why they fail are not properly fixed or loosened spark plug connectors and a missing backup flash over contact at the minus pole of ignition coil which leads to flash over of the spark back into the cdi box. So also my my black gen4 Permatune box died on this way. I don't suppose that poorer part quality or a poor electronics design is the reason why permatune boxes will fail disproportionately compared to other vendors like Bosch or MSD...but unfortunately I cannot name a reason why they may fail more often as others....but a Bosch CDI box will also die with a flash over back in the box...no question. Further reading on back flashes back into CDI boxes: section "back flaps" https://www-911--hkz-de.translate.goog/Zuendspulen.htm?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 06-22-2023 at 01:50 PM.. |
Dave |
Call Bob Ashlock. He can install his CDI unit in your aluminum case
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
There is no easy way to repair a unit that has been set in potting compound.
www.classicretrofit.com |
I met Lonnie (Permatune owner) in 2019 in Pittsburgh.
Told him I was having ignition issue with my 930 and he responded: "We can test your ignition system in our lab in Cleveland in just a day. Send us the module, coil, and distributor to : Perma-Tune Warranty Dept. 9197 Darrow Road Twinsburg, OH 44087 631.312.3280 His email address is lonnie@permatune.com
Find Spoke's LED Products: www.spokeworksled.com |
Had an older permatune in my 71 for a while, it seemed to work ok, it was installed probably in the 90s.
Had good luck with both Ashlock and the unit that parts klassik sells. had the latter in my 914/6 when the original CDI gave up the ghost... replaced the coil, cdi (with rev limit setting), and harness with the PK bits... |
Read post #4 here; Blue CD Box -- '77 911 (Question)
Dave Last edited by mysocal911; 06-27-2023 at 10:27 AM.. |
