Automotive Monomaniac
Emission's Avatar
Saw 260 F. at the track in both air and water cooled cars.
I ran a DE at Buttonwillow last Friday in my 930. It was hot - 96F. according to the thermometer outside.
Even with my "Oil Cooler Air Scoop", my oil temps would hit 260 F. during the heat of the day after a long run. I even pulled my fog light for more cooling - it didn't really help much at all.
Most interesting, I took a ride in a 2001 BMW 330i with an aftermarket oil temp gauge. As expected, temps were low at first, but then (after ten minutes of driving) the BMW also was indicating 260 F. for oil temp. The water temp needle remained perfectly in the middle of the gauge, as if nothing was unusual under the hood!
I was under the impression water-cooled engines kept their oil at a consistent temp. I guess I am wrong!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-10-2003, 11:27 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
260....ouch!
I have a rule that I follow...shut down before 250, that's just me and my little safety net.
With my ol' 2.7 I did see temps reach the 250 mark...then I added the Mocal cooler and never seen temps over 220!
With my 3.6 I have seen 230 but that's on the autobahn at 130 mph for extended periods...and if I just slow her down to 100 mph she will cool right down to 210 and stay there.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 06-10-2003, 11:38 AM
We've had to install extra oil coolers and shrouding on DE and race cars here on the west coast. They just can't get rid of the heat fast enough when the outside temp is over 90.
Our clients report 220-230 maximum temps when it gets this hot or hotter. That is why we also strongly advise oils that don't break down until much higher temps (like synthetics)
you need that extra margin of safety when running at places like Buttonwillow or Willow
Old 06-10-2003, 11:44 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Plus the guy in the bmw probably wasn't running 20-50. Like my mothers mercedes, the new german cars wanna see 10-40. Why i don't know, even thick synthetics seem kind of watery.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 06-10-2003, 11:49 AM
Emission's Avatar
Thankfully, I was running brand-new Mobil 1 15W-50 (changed it the night before). On the drive home, temps were normal again. I am going to put a shroud under my fender to force the air through the cooler next time.
Old 06-10-2003, 11:58 AM
74911s's Avatar
260 is way to hot unless you want to build a new motor.
Jim
R Gruppe Member once upon a time when you could run generators in Cambria to fix the cars and hit 150+ mph on the fun run
"Alles ist gut" 2011 997 GTS
"Orange Pepper Wagon" 2009 Cayenne GTS
Old 06-10-2003, 11:59 AM
My daily driver 92 audi has both water and oil temp readouts. Driven fast on the highway, the oil temp will creep up from ~185 all the way to ~240, but the water temp doesn't move much at all.
I assume that 240-250 degrees is just as bad in a water cooled car as it is in an air cooled, but I've heard that new corvettes normally run hot and that the VW VR6 engines sometimes run well above that range and don't seem to have many engine problems.
1977 911S Targa 2.7
Old 06-10-2003, 12:01 PM
MMARSH's Avatar
I only got slightly over 210 during a two hour enduro this weekend at Buttonwillow. I have a B & B cooler mounted in the front.
Michael
Old 06-10-2003, 12:09 PM
Bill Verburg's Avatar
There are several things to be concerned about w/ oil temps.
First - senders are only measuring T at one point in the oil circuit. That point is just down stream of the engine mounted oil cooler on the older(pre964 cars). You are not seeing the maximum T that is occuring in the engine. I would look for no higher than~220&degF on the gauge to leave a bit more of a safty margin. On my own car I like to keep it < 190&degFmax and change the oil more frequently as a consequence.
Second- Seals and other soft parts deteriorate at elevated rates, the deterioration is directly proportional to T. The seals in newer cars are better than they used to be but are still vulnerable.
Bill Verburg
Old 06-10-2003, 03:35 PM
With respect to the water temp gauge:
From what I've been reading in car magazines and on the clubb5 web site (for my passat), you can't put a lot of weight on the water temperature gauges in new cars. They do not really tell you what the water temperature is anymore. They have some electronics in them that will leave them at the set point if the temperature is within what it considers the normal range. It will move only if it goes way out of that range. According to Road & Track they do this to avoid people complaing about the exact operating temperature and comparing their car to other cars.
I have the same thing on our Passat. It does not matter how fast I drive, whether I have the AC on, or how hot it is outside. The temperature will rise quickly to the midpoint and stay right there for the rest of the drive. I kind of liked that info in the past as an indication how the engine was running. I gues they don't want you to know anymore.
Harold
89 911 Targa, 96 Saab 900S, 02 Passat 1.8T Wagon
02 BMW 530i, 08 Cayman, 17 GTI DSG
19 Subaru Forester
Old 06-10-2003, 04:14 PM
Emission's Avatar
Originally posted by Harold_89_911
"...they do this to avoid people complaing about the exact operating temperature and comparing their car to other cars."
Why even have the gauge?
I hate this dumbing-down process.
Old 06-10-2003, 05:12 PM
