Priming the MFI...?
Our 911E is ready for starting after many years,
When the key is turned on, it takes just a second or two for fuel to reach the injection pump....but cranking the engine for a few seconds doesn't produce any fuel at the injectors.....despite the fact that the injection pump was recently professionally rebuilt.
Does it take a bit for it to get primed?
Per
Old 06-10-2003, 01:24 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Just for the sake of Archiving,
Yes it does. I took me about 15 minutes of cranking, but you can take a big rubber band and a drill to prime it.
(Thanks Tyson)
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 06-10-2003, 01:40 PM
Thanks!
Thanks again,
I did a search on MFI and couldn't find it, must not have been looking hard enough.
I'm a little nervous about cranking so long as the car has already stripped one flywheel...
Per
Old 06-10-2003, 01:42 PM
Tim Walsh's Avatar
hmm... I'd say try the rubber band trick with that iffy starter (it did get fixed though didn't it?)
The trick is first mentioned under this thread from when I started my car.
w000t!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!111
Tim
1973 911T
2005 VW GTI
Old 06-10-2003, 01:44 PM
