kent olsen's Avatar
Still sitting on my lift
Out of frustration my car is still up on the lift. I have been unable to get the start switch back in the dash. Jumble of wires makes it very difficult to see what's going on. Soo yesterday I again tried to get the ignition switch mounted. In frustration, the problem is the shaft that goes to the steering column with a switch to lock the column when the key is off, anyway I took it out, put it in my vice and cut it off. Who cares if the column is locked when the key is off.
But I did get the ignition switch mounted and today I'll figure out which two plugs go where on the firewall. Then I'll figure out why I only get 7.5v at the starter from the ignition switch. Push comes to shove, I'll just wire in a start switch with 12v direct to the starter solenoid.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 07-02-2023, 09:14 AM
Little late but if you remove the plate with the rivets it goes in pretty easy.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 07-02-2023, 09:50 AM
Oh man. I am scared of anything electrical. Kudos to you for tackling this job!!! Lots of respect.
Silver 1987 Porsche Targa Carrera
Build thread: 87 Porsche targa! projects tracker
Still here
pmax's Avatar
Dang, is it worse on a lift when the human body doesn't contort that way ?
Old 07-02-2023, 11:37 AM
ROW '78 911 Targa
timmy2's Avatar
Hey Kent, been a while since we went for lunch with Paul Abbott in Salem!
Furthest right (when behind the wheel) female plug on firewall is ignition.
Moving left is wipers then signals.
PM me your number and I’ll call and walk you through some things to check for the voltage problems with a meter.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-03-2023, 09:58 AM
nothing to see here
If you have low voltage at the starter in the wire from the ignition switch check the 14 pin plug at the relay board in the engine compartment. Pin 1 is the one to check.
I recently replaced my ignition switch due to a non-starting car. I found the easiest access was to remove the driver’s seat and then to lie on my back with my head under the dash and in feet in the back seat area.
Old 07-04-2023, 12:12 AM
