-   -   30 to 3.2 SS CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/1142485-30-3-2-ss-cis.html)
Rusty 356 06-30-2023 09:06 AM
30 to 3.2 SS CIS
In the process of assembling Motorsport P&C
For CIS. Need to confirm the orientation of the piston. Attached is a pic of cylinder 6, the high part of the dome is toward the flywheel while 1-3 is toward the pulley. Is this the proper orientation of the pistons? Thanks,
Rusty
Maybe a photo uploaded
PeteKz 06-30-2023 11:21 PM
I don't see a photo. The dome goes away from the spark plug.
boyt911sc 07-01-2023 04:29 AM
CIS Piston Orientation Guide…….
Rusty,
This is how I remember the correct CIS piston orientation. Looking directly at the top of the cylinder/s, close your left fist (this represents the high spot on the piston) and point out your right fore finger (this represents spark plug direction towards the low spot) You must be facing the top of the cylinders when you do this inspection.
Left hand make a fist (high spot) and right hand point your fore finger out. Hope this helps you.
Tony
Nditiz1 07-01-2023 06:12 AM
1,2,3 side
http://forums.pelicanparts.com/uploa...1688217037.jpg
Rusty 356 07-01-2023 06:42 AM
Thanks guys, I think I got it right on 1-3 and had to turn the pistons so the high part of the dome faced the pulley. For whatever reason my photos wouldn’t upload.
Happy 4th!
Mark Salvetti 07-01-2023 08:22 AM
What mods are you making to the CIS? Different fuel distributor?
Thanks!
Mark
Rusty 356 07-01-2023 09:33 AM
Mark, same fuel distributor and intakes. Just changing the cams to 964 profile
al lkosmal 07-01-2023 09:51 AM
Piston orientation
http://forums.pelicanparts.com/uploa...1688230288.jpg
mikedsilva 07-02-2023 02:01 AM
Rusty
Exactly which pistons are you using?
Rusty 356 07-02-2023 07:06 AM
Mahle Motorsport
PS98-015 piston and cylinder set for CIS.
mikedsilva 07-04-2023 11:49 AM
Originally Posted by Rusty 356 (Post 12036106)
Mahle Motorsport
Can you post a picture?
Rusty 356 07-04-2023 05:30 PM
http://forums.pelicanparts.com/uploa...1688516767.jpg
http://forums.pelicanparts.com/uploa...1688516828.jpg
Not the best photos but I believe what is being said the low part of the dome should go under the spark plug.
Will post a picture of the piston alone tomorrow afternoon
Thanks and hope everyone had a great 4rh.
fabracadabra 01-26-2025 07:06 AM
Just wondering if you snapped pics of the final correct orientation for this Mahle kit?
I am nearing this stage and I would love to confirm orientation.
Thanks for the time
Chris
Rusty 356 01-26-2025 01:38 PM
Thanks for the time
Chris
Chris I’ll take a few picture Monday. Just starting another rebuild with the 3.2SS and post them.
Rusty
fabracadabra 01-26-2025 03:41 PM
Thanks Rusty, hopefully it looks like this on 4,5&6 ha.
http://forums.pelicanparts.com/uploa...1737934773.jpg
silverlock 01-27-2025 06:21 AM
Joe Engineer has some great pics: https://******************/porsche-911-heads-and-cam-towers/
http://forums.pelicanparts.com/uploa...1737987667.jpg
fabracadabra 01-27-2025 12:12 PM
Silver lock thanks for that he does have excellent pics. Looks like I got mine in there correct on 4,5&6
