30 to 3.2 SS CIS
In the process of assembling Motorsport P&C
For CIS. Need to confirm the orientation of the piston. Attached is a pic of cylinder 6, the high part of the dome is toward the flywheel while 1-3 is toward the pulley. Is this the proper orientation of the pistons? Thanks, Rusty Maybe a photo uploaded Last edited by Rusty 356; 06-30-2023 at 09:08 AM.. Reason: Photo didn’t upload |
PCA Member since 1988
I don't see a photo. The dome goes away from the spark plug.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
CIS Piston Orientation Guide…….
Rusty,
This is how I remember the correct CIS piston orientation. Looking directly at the top of the cylinder/s, close your left fist (this represents the high spot on the piston) and point out your right fore finger (this represents spark plug direction towards the low spot) You must be facing the top of the cylinders when you do this inspection. Left hand make a fist (high spot) and right hand point your fore finger out. Hope this helps you. Tony Last edited by boyt911sc; 07-01-2023 at 04:55 AM.. |
1,2,3 side
83' Coupe - Ex-RaceCar 77' Targa Narrow Body - SC powered Copper Brown Metallic |
Thanks guys, I think I got it right on 1-3 and had to turn the pistons so the high part of the dome faced the pulley. For whatever reason my photos wouldn’t upload.
Happy 4th! |
What mods are you making to the CIS? Different fuel distributor?
Thanks! Mark
1979 911SC Targa |
Mark, same fuel distributor and intakes. Just changing the cams to 964 profile
Piston orientation
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Mahle Motorsport
PS98-015 piston and cylinder set for CIS. |
Can you post a picture?
![]() ![]() Not the best photos but I believe what is being said the low part of the dome should go under the spark plug. Will post a picture of the piston alone tomorrow afternoon Thanks and hope everyone had a great 4rh. |
Just wondering if you snapped pics of the final correct orientation for this Mahle kit?
I am nearing this stage and I would love to confirm orientation. Thanks for the time Chris |
Rusty |
Thanks Rusty, hopefully it looks like this on 4,5&6 ha.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/ Gear Ratio (Speed @ RPM) calc: https://ratio.questionable.services/ |
Silver lock thanks for that he does have excellent pics. Looks like I got mine in there correct on 4,5&6
