Help: AC and power seats quit working at same time
I have an '87 911 and last night I started the car with the AC in the "II" position - normally I turn it off before starting the car. Just after the engine was running the AC quit blowing. I pulled the fuse (no. 2 in the fuse box) and it was fine, but I put a new one in just in case. I restarted the car and still no AC. The AC and power seat fuse are the same so I tried the seats (4-way)and they will not move (they worked this weekend). Any ideas what else I can check? Thanks.
Old 06-10-2003, 08:09 AM
Heck, I’m only 5 not 71!
targa80's Avatar
If the fuse is good you might have lost the 12 volts to that circuit. You need to put a voltmeter between the fuse terminal and ground to see if the battery voltage is there.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 06-10-2003, 08:12 AM
This just happened to me yesterday....yep, even the fuse looked OK like yours did.
I still took the fuse out, and *really* cleaned the fuse contacts, and also bent the tabs a bit because the fuse wasn't held very tight. checked continuity on both old a new fuses and both were good. Replaced fuse just as a precaution. You might get the same result by simply rotating the fuse back and forth on the holder.
Now it's OK ....
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-10-2003, 08:27 AM
Toxic
derkpitt's Avatar
Wait a minute, your a/c worked?
After a complete rebuild, mine's working real good until OAT is above mid 80's. Then it starts sucking.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 06-10-2003, 09:27 AM
DP,
How are things at NUMA?
Describing an AC as "working" is always relative. The AC in my '70 Barracuda Gran Coupe convertible "worked", but didn't "cool". With my 911, the AC was working until the day the heatwave arrived.
targa80 and Wil Ferch - thanks for the suggestions - I will revisit the fuse block and connections tonight.
Al Giordino
Old 06-10-2003, 09:55 AM
Same problem with me about a week ago. Had to bend the tab back in to insure good pressure on the fuse. Fixed mine immediately even though it "looked" like it was contacting.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-10-2003, 03:56 PM
