Fine tuning corner weights
I'm corner weighting the SC, and have the following (in pounds):
563__521
837__808
Total weight with a full tank of fuel and my butt is 2729 lbs.
Anyone that has done this before have any comments on how the numbers look?
I've got the diagonal weights at 50%, but was hoping to get the fronts a little closer to each other. I autox in stock class, so I can't move any ballast around.
Rob
1980sc
Old 06-09-2003, 06:22 PM
ttweed's Avatar
GO HERE to Thom's calculator and plug in your numbers.
Looks like you're within 7 lbs. of ideal weight on the corners, so I'd call it close enough and wouldn't mess with it.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 06-09-2003, 06:32 PM
Hey Thanks !
How is that page determining "ideal" weights?
I just made one minor adjustment (it's fun, I can't help it) and got :
556__525
846__799
When I plug those numbers into Tom's page, it says my weights are the ideal weights (within 1 lb). Are they really? I would think a better side to side balance would be more ideal.
Thanks,
Rob
1980sc
Old 06-09-2003, 06:52 PM
These cars will have a front to back split and a right to left split, so the weights will be heavier on the left. (I guess RHD would be opposite)
Old 06-09-2003, 08:47 PM
ttweed's Avatar
Good job! Within 1 lb. is very accurate. You'll probably change more than that just by running your gas tank down.
You'll not get a better side to side balance in a 911 Porsche with the driver's weight in the left seat (or right seat, for your RHD countries) without relocating some heavy things on the chassis somehow.
That's not important to your handling balance, luckily, what you want is for the F/R weight distribution to be the same on the left side as it is on the right. This will insure that the tendency to under/oversteer is the same when turning both ways (given that the rest of your setup is equal side-to-side). Of course for roundy-round racing, it's a whole 'nuther ball game...
TT
Tom Tweed
R Gruppe #232
Old 06-10-2003, 05:56 AM
Look up posts that I made in addition to Thom and Chuck Mooreland. Went into considerable detail. For "tin-can" cars like ours diagonals being equal is *not* the target ( good for Formula type cars, though). Target should be LF/LR=RF/RR ....or ...LF/RF=LR/RR. Lots to say about this as to "why". See our archived ( lengthy) discussions on this.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 06-10-2003, 08:33 AM
So Wil, why are the ideal weights closer to equal diagonals than to equal side to side weights?
Side-to-Side
Left 1402 51.43 %
Right 1324 48.57 %
Diagonal Weight
Left Front / Right Rear 1355
Right Front / Left Rear 1371
Since our cars aren't set up like an indy car how are we supposed to get equal weights left to right short of having one side higher than the other?
Old 06-10-2003, 09:03 AM
Chuck Moreland's Avatar
Have a look here:
http://www.elephantracing.com/techtopic/cornerbalance.htm
Your numbes look pretty good!
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-10-2003, 09:21 AM
Nevermind, I found the archived thread in question with the big discussion, Quick Corner Balance Question!
Here's another good article
http://www.pelicanparts.com/techarticles/911_alignment_tips/911_alignment_tips.htm
Old 06-10-2003, 09:23 AM
Whew, thanks...i didn't want to go through *that* again
--Wil
Wil Ferch
Old 06-10-2003, 10:58 AM
Ah, I see now.
My diagonal weights are only slightly different at 50.3% and 49.7%.
But more importantly, both of my front wheels have 39.7% of their side's weight.
Thanks alot !
Rob
1980sc
Old 06-10-2003, 02:42 PM
