Help putting together a 902/1 Clutch assembly
Hi Everyone. Long time reader first time poster.
I have recently rebuilt a 902/1 gearbox from a 66' model car for use in my porsche. It didnt come with a clutch release arm/fork or any of the clutch components in the bellhousing. I looked up what it should have and have purchased the ball-pivot direct from porsche, a sachs clutch release bearing, the spacer pads between the bearing and the fork/arm and a second hand arm. The Arm has the part number 90111671200 stamped on it. When i attempt to assemble it, the ball-pivot appears to be too close to the input shaft to work with the release lever. Looking online there appears to be two types of lever that use the ball-style pivot one with the pivot dimple inboard and one with it further outboard. Mine appears at least to have the dimple furthest toward the release bearing so I'm totally lost as to what it could be!? Everything appears to match up with the part numbers they should be (from exploded diagrams). One thing i did notice is some bellhousings have a more pronounced area where the ball-pivot resides - this is simply a threaded hole in the back of the bellhousing. Any ideas folks? Pictures follow ![]() ![]() ![]() ![]() ![]() ![]()
PCA Member since 1988
If you don't get an answer, try directly contacting Matt Manson at GT Transmission. He can probably tell you exactly what parts you need from memory.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It looks like you are showing two different arms?
The arm on the bottom
is what you need. 711 instead of 712.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 07-12-2023 at 12:51 PM.. |
