Vertical steering wheel play after swapping steering wheel
Removed my OEM steering wheel, and installed a MOMO Prototipo Black Edition. And after installing, the steering wheel has vertical play slightly. Up and down only. The end of the bolt in the photo moves with the steering wheel when it moves. Do i need to tighten these? Only reason i could see it being lose after install is i used an impact and the vibration could have caused it to come loose. But i dont know. Need advice
https://ibb.co/C1mrvz8 |
Sometimes this antique ass forum pisses me off. Photo link wont post.
There is an easy bearing you can install, 10 minute fix.
What year? Fix for 74+ different than earlier cars.
Please add you car to your signature line. Help us help you. |
Its an 87 carrera
I ordered the Rennline nylon steering column support bushing through pelican. Thats what i needed right?
That should work for you.
The part i put in my SC was a upgraded part for a 928 metal not plastic. P/N- 92834773902 available from our host.
What was the issue ?
I have said bushing and a plan to install - I'd too like to understand the called out issue before I proceed.
Will update after it comes in and i install
https://forums.pelicanparts.com/porsche-911-technical-forum/372487-problems-arising-metal-steering-bushing.html Quote:
| All times are GMT -8. The time now is 02:49 PM. |
