2002 911 Oil Drain Plug
Oil changes on my 911 for over 10 years myself. This time I stripped the hex oil plug, Any recommendations how I can break loose the oil plug? Thanks,
Use an Easyout. Grind off the end so it fits snugly into the hole, pound it in, go to town. Replace it of course.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
you referring to screw extractor and left hand drill bit? 2nd photo is what i picked up Lisle T-55 tork bit that i would need to slightly drill out the hex oil plug for this to fit tight.
PCA Member since 1988
Why does your oil plug have such as small Allen socket? Oh yeah, it's a 2002...
When you replace it, use something with a bigger Allen or hex head.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Red Line Service
Yup, LN magnetic plug. Soft,soft,soft. They recommend 19 ft/lbs, when Porsche requires 37 ft/lbs to properly crush the seal washer. Garbage. The factory Alu wears out over time also, but we put the LN's in the circular file!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Thanks for the feedback the hex socket that i have is little loose to take the new plug and fit a tighter hex head. Yes that is a LN magnetic plug not again.
