cam timing setting
Looking for suggestions to set cam timing on a 3.0 with 964 cams and 9.5 JE pistons
Thanks in advance for your help!
Old 07-26-2023, 05:02 PM
walt's Avatar
I have 964 cams with stock pistons. Been running 1.25 mm but just recently advanced to 1.50. Engine not back in yet so can't offer much feedback on the change.
Walt
82SC 3.0
81SC 3.6
Old 07-26-2023, 05:57 PM
964 spec.
206 637 4071
Old 07-26-2023, 06:11 PM
Jeff Alton's Avatar
What John said above.
www.turn3autosport.com
Old 07-26-2023, 07:18 PM
Thanks for the answers-I will start with 1.25
Old 07-27-2023, 05:17 AM
walt's Avatar
A while back when I was researching this subject I saved these threads. Maybe one you haven't seen yet.
Installed 964 cam in 3.0 SC!
964 cam timing please
911 sc 3.0 performance upgrades
cam timing question for 964 cam on SS 3.2
Walt
82SC 3.0
81SC 3.6
Old 07-27-2023, 07:27 AM
I've fitted a few of these over last couple years. And from advice from more experienced people, I found that timing spec changes the characteristic of the motor.
The 964 factory setting is 1.26mm. But if you advance to 1.5 you tend to bring the peak torque a little earlier in the rpm range. The trade off is you will likely have lower top hp.
The difference between the 2 settings is noticable, but neither is going to make you feel regret for not going the other way. Also, keep in mind you need to ensure adequate valve-piston clearance. However with your JE's in this case, I suspect you'll have plenty.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-27-2023, 11:10 AM
