JCFL
Location: Caraquet, New Brunswick, in eastern Canada (600 miles east of Boston)
Ground location under dash - anyone with photo ?
This is the last ground I must verified, and I am a bit physically challenged to get a good look under the dash.
Does anyone has a good photo of the exact location of the ground ? Thank you. Jacques
Jacques 1986 911 Carrera Coupe - since April 2022 1982 911 SC - 2010 - 2017 1984 911 Carrera Coupe - 2006 - 2009 |
PCA Member since 1988
I don't have a photo handy. In my car it's pretty close to center under the dash. Use a mirror to look up underneath and you will see it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
If you're talking about G206, this is it:
Gilles RoW 88 Carrera coupé |
It’s about 2 inches left of the ashtray and about 4 inches back.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
JCFL
Thank you guys.
Viva 911 Tech Forum by P. Parts.
