Installed new alternator. SMOKE
Installed new bosch alternator and the battedy terms were sparking like crazy when i was trying to reconnect them. Then smoke billowed out of my alternator. Turns out the large brown ground wire from motor to alt came loose from its clamp on motor side. And grounded itself.... hoping i didnt just fry brand new VR..does anyone know the part number for that ground wire.
Old 07-31-2023, 11:39 AM
pete3799's Avatar
A ground wire grounding itself won't cause that.
You sure the reds are on B+ and the browns are on neg.? Or you hooked the battery up backwards?
Pete
79 911SC RoW
Old 07-31-2023, 12:27 PM
Battery is correct orientation. I installed everything before, and didnt install fan extension, people on another forum suggested i install the fan extension. So i pulled everything part, and dinit all again installing the fan extension fin cone. And then this happens. Im kinda at a loss.
Old 07-31-2023, 12:55 PM
Also the post i put the 2 brown wires on was labeled BR by rebuilder.
Old 07-31-2023, 01:12 PM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
BR doesn't designate BROWN. It usually designates the main output terminal of the alternator.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 07-31-2023, 01:22 PM
Wait so what does that mean
Old 07-31-2023, 01:32 PM
I just double checked, and the wires were run correctly
Old 07-31-2023, 01:34 PM
E Sully's Avatar
Here's the ground wire. Part number #911 612 233 00
If it helps here's a picture of my '86 alternator wiring, although from what I can see yous seems correct. It doesn't make sense though for it to short out by grounding the ground wire. Did it touch one of the Red 12V wires?
Ed
1973.5 T
Old 07-31-2023, 01:35 PM
The ground strap wire that melted and smoked out because disconnected from the eyelet thats attached to motor. Cause a loose haphazard connection. Im 90% certain that breached connection is what did it. After removing the rotten ground wire i touched pos lead of battery back to post and there was no sparking or smells or smoke.
I ordered a replacement wire from pelican... now i wait, really really really hope i didnt damage new alt or VR.
Car is a '87 911
Old 07-31-2023, 01:43 PM
Still here
pmax's Avatar
B+ Positive (Red)
Old 07-31-2023, 03:01 PM
Still here
pmax's Avatar
Where's the nut and washer securing the wires to the terminal ?
Old 07-31-2023, 03:10 PM
HarryD's Avatar
Hope you had no damage.
However, letting the magic smoke out is almost always a bad. If you had a British Car you could use this to restore the system.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-31-2023, 03:31 PM
@harryD That is classic. I have bottles of those for my MG.
Old 07-31-2023, 05:26 PM
The housing grounds the alternator body and the fat brown ground wire to the engine case is just to make sure. If there's a ton of corrosion on or in the housing or on the engine case where the housing contacts, the ground is compromised and the extra wire becomes more important, so you might want to clean things up if needed.
206 637 4071
Old 08-01-2023, 09:49 AM
Still here
pmax's Avatar
Car is a '87 911
Tread carefully before trying more "what if I do this" experiments. Don't assume there's no other damage to the harness waiting to short out.
Old 08-01-2023, 03:00 PM
