Ubi bene ibi patria
Hawkeye's-911T's Avatar
Headliner "Hold-down" Strips
Hi All
I am about to install a new headliner in a 1970 coupe. I would like to find a source and or a part no. for these strips:
They appear to be constructed from a type of cardboard/paper material.
Dims: 29mm (1 1/8") wide x 2.4mm (3/32") thick x 280mm (11") long. They are located at the base of
the "C" pillar where the headliner transitions to a contact area under the parcel shelf cover They were
originally held in place by spiral nails (?). I believe some form of sheet metal screw as a viable replacement
for the nails would be a logical upgrade.
Thanks in advance.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 08-03-2023, 12:16 PM
I just made some of these today out of thick brown posterboard…please post if you find a source
it's not leaking....it's just marking it's territory
Old 08-03-2023, 03:11 PM
Soak them in warm water until saturated, lay on a flat surface, flatten them, put weights on them until dry.
Nothing better than original parts.
Old 08-03-2023, 04:20 PM
