Dave |
nothing to see here
The injectors need a good earth - were any disturbed during the engine removal?
If you have a noid light, you could connect it to one of the injector leads and see if you are getting an injector signal. you could also check to verify that you have 12V at the injector. the injectors should receive 12V form the 87 pinon the DME relay with the ignition in the run position. IF you test for 12V with only 1 injector disconnected you will actually show 12V on both pins of the plug as the injectors are wired in parallels and you will have voltage passing through the coils of the remaining connoted injectors to the DME controlled side, which is ungrounded when the engine is not running. |
Dave |
Injector plug #1 resistance tested within spec at 3ohm But it DID NOT light the test light with the ignition switched to “on” or on the start crank. I believe that fuel is getting to the rail from the pump (36psi) and the injectors are not getting power.
-Mike 1987 911 Carrera Coupe |
Dave |
Problem Solved!
I was reading up on injector threads and came across this one, which referred to a six-prong connector near the firewall. I didn’t remember disconnecting or re-connecting this switch, so I went out to find it…unplugged. I’ll have to double check, but I don’t recall the Bentley listing this one as a step. This forum has been great. I’ve learned a ton through all the help here and troubleshooting some fairly easy, but seemingly complex, issues. Thank you. Tomorrow…we drive.
Ethanol sucks
Fuel filter replacement Fuel pump pressure check valve replacement Just did this Car would crank for 5-10 minutes on and off Finally started. After 40 plus years, ethanol has ruined the fuel pressure check valve….cheap Fuel filter was cheap, You state it starts when you spray fuel cleaner into the intake. Spark is not the issue. |
Still here
I say there's a good chance the engine "unplugged" the connector for you during the drop. That thread has some oscilloscope traces of the sensor and injector waveforms. https://forums.pelicanparts.com/porsche-911-technical-forum/748619-injectors-not-spraying-4.html#post11792513 has som |
Now I have to figure out why it’s running rough and the cat was red hot after a short drive tonight…
