LinkBack | Thread Tools | Rate Thread |
Throttle linkage ball joint popped off and ruined my night - what do I replace?
Hi-
Got stranded for the first time tonight on PCH in Laguna Beach, CA - unfortunate timing but fortunately driver and car safe. Upon getting it home I found the ball joint had come off the ball on the triangular pivot piece that attaches to the transmission. Car is a '87 Carrera - I presume that perhaps just wear over 120k miles requires a new cup? What else would be prudent to replace (the pivoting piece as well since that has the ball joint on it?) to ensure this does not happen again. Is there adjustment needed that would be better for a shop to look at or is this a wear/tear issue? Thanks very much, got it popped back on 2 minutes ago in 5 minutes w/ the car on a jack w/ a pair of pliers, but won't drive the car until I resolve whatever the outstanding issue(s) are. Also in case the Steve in a killer sounding 993 whose plate starts with a "N" is reading this THANK YOU! You were the only person to stop and offer assistance in over an hour on the side of the road. I didn't catch your last name but shoot me a PM would love to buy you a drink. |
That's an easy fix, maybe it was dislodged by road debris. Snap it back on and if it feels secure and cannot be removed easily then move on. Otherwise its a simple replace of that section of the accelerator rod, plus replace the plastic bushes at the same time while you are under there.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
That use to happen all the time on my 72. When I bought the car you could tell that the rod must have fallen out completely and maybe run over as it looked to be bent back into shape. Took me many times to get it bent just right so it would not pop off again. Mine would only come off during WOT. Yours might have just popped off, or it might need a little bending, etc. Good luck
72 911 Although it is done at the moment, it will never be finished. |
There is a pin that goes through the socket then flips to snap in place. It prevents the ball from popping out. They are 7 bucks and are used in other places of the linkage.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
I was going to mention the pin in the ball clip.
Bruce |
I'll order a new ball socket and a couple pins as well. Any other common failure points? Should I out of paranoia swap out every connection down at the pedal cluster as well in your opinion? |
I need me some pins, where art thou pins? Mine has fallen off in years, but better safe than sorry.
You have to have engine on the floor with the trans to get the pin in.
Bruce |
No pins for me!
Not in my 87, the bottom transmission bellcrank is accessible without lifting the car, I think that is the one the OP had the problem with.
On my car there are 4 total. 2@ at the linkage mounted to the trans and one each at pedal cluster and back where the linkage rod goes up to the Fuel injection. PET calls for a clip of some sort at he pedal cluster, but nowhere else. So far I've changed the 2 @ the trans and the bushings on the arm attached to the trans. This winter on my project list is to change all the bushings through the tunnel and the rest of the ball cups.
I think that Porsche changed the engineering through the years so YMMV. I do know that when the hand throttle went away there were other changes as well. -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Have those of you who run without pins replaced the ball cup and not had this happen again? As this is a car the kids are occasionally in I don't want to cut any corners.
No prob with my pins, and as for your earlier question I used the nice bronze bushings. I did have the car up with engine in and I did it from underneath when I cleaned up the pedal cluster and some other things.
![]() edit: doh! upside down?!
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Laguna Beach. Good thing all the riff raff that live around there didn't come and rough you up
You can buy the ball thing through our host
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
I've got the opposite problem. I have the engine out of my '88 and have removed the safety pin/wire but having trouble getting the accelerator link on top of the engine to pop off. I have used large screwdrivers and couple other things with no success. It seems like I'm having to put a LOT of pressure on it to get the socket side to pop off the ball side. Any tips?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Same thing happened to me also on my 88. I was never able to separate the ball from the socket. So I ended up unscrewing the linkage on the engine side and keep the socket on the ball.
Gilles RoW 88 Carrera coupé |
Yeah, loosen the 8mm nut and turn the rod.
Ok that makes sense, it crossed my mind but I was worried about getting it back on at the right adjustment point. I'll just make sure and not how many threads it's at now. Sometimes the simple solution is the best!
Just leave the nut in place on the rod. Just needs a slight turn to loosenit.
