gptom's Avatar
adding multiple pics
As in how do I do it? I have been loading 1 pic at a time
TIA
68 Beetle 68 to 72 sold
72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army
67 VW split window 74 to 76 sold
81 VW caddy 81 to present
Old 08-18-2023, 03:24 PM
Go to [post reply] and follow prompts
Bruce
Old 08-18-2023, 03:51 PM
Discseven's Avatar
Start to finish...
After clicking on "Reply" or "Quote," this is what is seen. Click "Go Advanced."
Next, click the blue "Click Here to Upload Photos."
This is what is seen next. There are two ways to upload photos. 1: Drag and drop files into the white panel. 10 Photos per individual post are the max and 5 mb is the size limit per photo. When done dropping files into the white panel, click "I'm Finished - Close this Window." 2: The other way is to click "Choose File." That will bring up a folder from your system. Navigate to where your images are in your system/drive and click on the one you want to upload. Then click "Upload Now." This is a one at a time path where if you want to upload more than one image, that "Choose File" and "Upload Now" has to be repeated for each individual upload. The Drag and Drop path is easier but it's possible that not all computers can do the Drag and Drop.
Pixel dimensions of an image controls how large it displays in a post. You have to experiment with pixel dimensions to determine what image size you prefer to display. Images I posted are 480 pixels wide.
To see how a post looks BEFORE posting it, it can be viewed by clicking "Preview Post." If editing is desired, return to the working area below the preview area and do whatever. Once a photo is uploaded, it's not possible to edit a photo and upload it again with the same file name. To REPLACE a previously uploaded photo, the file name must be changed before uploading the edited photo. If this is not done, the previously uploaded image will remain posted. Of course the previously unwanted photo has to be deleted from the post so only the new image gets posted.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 08-18-2023, 11:23 PM
