-   -   Looking for a source for CIS Injector Tubing (http://forums.pelicanparts.com/porsche-911-technical-forum/1144955-looking-source-cis-injector-tubing.html)
rich 08-18-2023 03:46 AM
I have a 73 2.7S and need to refurbish the CIS. Anyone know where I can purchase bulk plastic tubing for the CIS fuel lines?
GregSC 08-18-2023 04:37 AM
BelMetric carries several sizes and types of fuel hoses, including polyamid, which may be what you’re looking for. Give them a look online, I’ve had good success with them in times past.
Schulisco 08-18-2023 04:57 AM
Forum search is always a good tool
https://forums.pelicanparts.com/search.php?searchid=25319219
Thomas
fanaudical 08-18-2023 06:43 AM
Be careful sizing/sourcing the fuel tubing. There are multiple sizes in the CIS system.
The correct polyamide tubing for CIS injector lines (from the fuel distributor to the injectors) is Cohline part number 3012.0206 which is 2mm ID x 6mm OD.
There are others selling tubing with reduced wall thickness that will lead to injector pulsation over time.
I have not found the Cohline injector tubing available for sale in the USA the last time I purchased some (~18 months ago). I had to order from Europe:
https://cohpro.com/product/polyamide-tube-2mm-id-6mm-od/
Oregon 911 08-18-2023 06:44 AM
Try the online company belmetric.com
They specialize in selling metric fuel lines vacuum lines and all kinds of metric fasteners.
They carry different sizes of the polyamid plastic line that is used for the fuel injection lines. Hope this helps.
It looks like the information posted just above mine is better to go by from fanaudical It sounds like he has the better source in Europe to order from
rich 08-18-2023 07:27 AM
Thanks! Great Response!
BTW I did a search but came up with Zip. Possibly my search words but anyway I knew someone would have a source.
Schulisco 08-18-2023 08:26 AM
https://urlis.net/1hybc80a
https://urlis.net/poue0gu1
Unfortunately out of stock currently.
When you search with the Porsche Part number (see from the links above) you get much easier some results:
911.110.093.11
911.110.093.12
https://urlis.net/ysg6tdar
https://urlis.net/u22j704u
Thomas
rich 08-18-2023 09:37 AM
When you search with the Porsche Part number (see from the links above) you get much aeasier some results:
911.110.093.11
911.110.093.12
Thomas
Thank you sir. Just want the bulk tubing without fittings.
theiceman 08-18-2023 10:16 AM
what about the exterior sheath that goes around it ? mine all broke away .. i'm sure it is not required but just does add that finishing touch.
Schulisco 08-18-2023 11:02 AM
I wouldn't take the risk and replace it. When the exterior sheath broke, then the rest won't be in better shape... The costs to replace it are literally nothing compared to a burned down 911...
Thomas
Marwil 08-18-2023 11:35 AM
You could also try Belmetric dot com something. They have fittings and tubing. The exterior rubber is for protection against chafing I think, it will crack. The Polymide tubing is very stable, however, in comparison to the rubber.
rich 08-18-2023 11:40 AM
Belmetric responded. No tubing. Checking the Cohpro. Waiting for a response.
Mark Salvetti 08-18-2023 12:54 PM
Try Unobtanium Supply. Ferrari's had CIS. They list kits in their catalog: http://www.unobtainiumsupply.com/UnobtainiumSupply_Product_List.PDF
They also have a tool for attaching the fittings, which is not a trivial exercise. See the last page.
These guys too: CIS Fuel Injection Fittings, Line, Banjo Fittings Midwest Shop Supplies
Lots of good threads here on replacement, here is one: http://forums.pelicanparts.com/porsche-911-technical-forum/1021937-how-make-fuel-injection-lines.html
Or have BoxsterGT make you a new set.
Mark
E Sully 08-18-2023 02:27 PM
I ordered from Verell Unobtainium at Ferrari Chat back in 2011 and the tubing was correct for my '73.5
Heres the old thread. The J2 Precision links seem to be expired
http://forums.pelicanparts.com/porsche-911-technical-forum/595988-cis-fuel-lines.html
The line Verell sold was Cohline 3011 3106 HIPHL-23. 6mm od vinyl Polyamide (vinyl) tubing. You don't want anything with a thinner wall as it could flex enough to cause injectors to pulse.
This is the closest I found from Cohline https://cohpro.com/product/polyamide-tube-3-15mm-id-6mm-od-black/
47silver 08-20-2023 07:02 AM
Len (boxstergt). Is the tubing guru.
Send your fittings to him, get new ones back
Len Cummings
len.cummings@verizon.net
It is doable on your own. Search here for people that did them
BoxsterGT 08-27-2023 02:12 PM
This......
http://forums.pelicanparts.com/uploa...1693170241.jpg
http://forums.pelicanparts.com/uploa...1693170532.jpg
http://forums.pelicanparts.com/uploa...1693170596.jpg
len.cummings @ verizon.net without the spaces.
Travis Neff 08-29-2023 04:23 PM
Parts Klassik has the bulk cohline polymide
p-1863-polyamide-line-3mm-thick-wall.aspx
rich 08-29-2023 07:47 PM
Hey Travis!! Miss you guys! I ordered some from Cohpro. It was super cheap I ordered 6 meters was less than $ 40.00 shipped.
rich 08-29-2023 08:09 PM
The Alien had to Christen the new driveway
http://forums.pelicanparts.com/uploa...1693364474.jpg
HarryD 08-29-2023 09:20 PM
FWIW, the early 911 CIS did NOT have the sheath on the tubing.
fanaudical 08-29-2023 09:50 PM
That's 3mm ID x 6mm OD - Not the 2mm ID x 6mm OD used by Porsche...
HarryD 08-29-2023 10:04 PM
It matters. Read this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/236328-cis-misfire.html
Travis Neff 08-30-2023 08:30 AM
Miss ya too Rich!
As for the sizing, I just knew of a vendor who carried bulk in a variety of sizes - I didn't do a deep dive. Good to know on the 2x6 vs 3x6
mikedsilva 06-20-2025 04:00 AM
Just bumping this to get some more info.
What are the ID sizes needed for the different lines on the 911 CIS ?
Injector lines look to be 2mmID and 6mm OD
What about the WUR to FD line?
Cold start injector?
Supply and return lines?
Any info appreciated.
Mike
mikedsilva 06-20-2025 04:32 AM
Mike
Ron.G 06-20-2025 05:18 AM
I just replaced the line that goes to the bottom of the Accumulator. This line is the same as the rest of the lines going to the back of the fuel distributor.
M6X8 Polyamide. I ordered it from belmetric.
