I wouldn't undo the O2 sensor on a DME car. However, you can replace it for 50 bucks, plus the cost of the wrench, by using a Bosch unit intended for Fords-do a search for a thread Wil started on o2 sensor info.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Bosch p/n 13853. 50 bucks at Pepboys. The thread is here:O2 Sensor.. Alert ! ..and new info
THANKS FOR YOUR INPUT GREG.
MUCH APPRECIATED
1984 911 TARGA (FIRST U.S.A CAR) ALL EX SOUTH-AFRICA 1987 911 COUPE 1982 911 SC COUPE 1982 911 930 TURBO 1981 911 SC COUPE 1974 911 TARGA |
i am going back to my questions on the idle stabilizer as per my quote.....any ideas. b.t.w when a/c comes on the idle is even rougher which leads me to believe that the idle stabilizer is not doing its job. thanks
If you haven't already, check the vent hose that attaches to the back of the oil filler neck. It is a few inches from the top of the neck. You have to pull on it to see if it's attached. If it's unattached it can have a similar effect to the filler cap being off.
Dan Morissette '85 Guards Red Targa 911 My Owners Gallery Page Non illegitimi carborundum |
Look, if all else fails, I'd get a reputable shop to check your baseline mixture and go from there. Don't take this the wrong way, but you've messed with it in a blind fashion. It might well be something else (ISV, maybe) but I'm suspicious of messing with the mixture screw blindly. The reason I say that is that even the "limp" mode on the DME is pretty good, and it will be completely thrown off if the mixture is something other than the baseline it assumes.
To check the idle speed controller, remove it and connect a pipe in it's place and squeeze the rubber hose enough to get a steady idle. See if it's better.
Be careful for the engine will rev very high if you start it with no squeeze in the hose. I don't know how high and don't want to find out. I also have a 3.2 with a doggy idle. Ned |
thank you guys. will try the suggestions.
thanks for the replies
