T1R1's Avatar
Engine ID ?
What's an easy way to tell which engine I have?
I just bought the car from someone who knew nothing about it. (much like myself ) Since it's a '77 I assumed it had a 2.7 but some of the things about it now that I'm working on make me question maybe someone in the past may have upgraded.
Ted
'77 911 Targa
Old 06-15-2003, 09:43 AM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Engine Serial Number will be very helpful... located vertically on the right hand side by the fan.
Jordi Riera
'84 930 (modified)
Old 06-15-2003, 10:32 AM
RETIRED
Joe Bob's Avatar
Get the engine number.....it will say 930/XX, it's a fainter one above the engine serial number. Both are next to the oil sender, bottom right while looking at the engine with the lid open.
2012 ML350 3.0 Turbo Diesel
Old 06-15-2003, 10:58 AM
Alan Cottrill's Avatar
if all you want to know if it's the 2.7l look at the passenger side of the case under the cylinders look for 7R at the end of the case casting number.
big AL
'77 911
Old 06-15-2003, 11:16 AM
Hilbilly Deluxe
emcon5's Avatar
Hopefully it will say 930/xx. If it is a 2.7 it will say 911/xx.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-15-2003, 11:37 AM
T1R1's Avatar
Thanks guy's,
Here's what I found. The vertical #on the fan next to the oil sender is *62758821* Behind the sender on the flat surface is stamped 911785 and on the case on the left hand side just above the lower valve cover is 901.105.111.1R
What Engine? Thanks!!!
Ted
'77 911 Targa
Old 06-15-2003, 12:28 PM
Mikkel
Guest
Posts: n/a
Hmmm seems to be a 1977 US 911S 2,7 engine. Type 911/85 I think.
Old 06-15-2003, 12:41 PM
Hilbilly Deluxe
emcon5's Avatar
Originally posted by T1R1
Thanks guy's,
Looks like the stock engine.
6= 6 cyl
2= engine type, in this case 911s (USA) (CDN)
7= 1977
8821= Sequential serial number
Should be 911/85, 165hp US 50-state CIS engine, which is the engine type for the listed serial number.
Tom
82 911SC Coupe
GTI Cup #43
Old 06-15-2003, 12:42 PM
T1R1's Avatar
Thanks All, you're right I read the / as a 7
Ted
'77 911 Targa
Old 06-15-2003, 02:34 PM
