-   -   Rotary A/C Compressor (http://forums.pelicanparts.com/porsche-911-technical-forum/114602-rotary-c-compressor.html)
scottb 06-12-2003 11:16 AM
What advantages does a rotary a/c compressor have over the stock Nippondenso in my 84?
Anyone have a rotary they'd be interested in selling?
JackT 06-12-2003 11:29 AM
The advantage is less strain on the motor. You can bearly feel the rotary compressor when it cuts on.
1fastredsc 06-12-2003 11:35 AM
Well, as you know, i don't have one, but i believe the advantages mechanically are that the rotarie's are smaller and lighter. Because of mechanical design, rotaries go through a "pump" cylce three times per revolution. Therefore it can be smaller than a piston pump but yet compress the same volume since it does it more times per rev.
sithot 06-12-2003 11:42 AM
Correct on all counts. Rotarties can be felt in our engines; the pulsing of the pistons. When you turn on the a/c you will feel the compressor. Good time to change out and go with the new coolant (R134) as well. Freon is not going to get any easier to find and it is expensive.
scottb 06-12-2003 11:52 AM
Aside from it being smoother, does the rotary provide any additional cooling?
JackT 06-12-2003 11:55 AM
I changed to rotary and at the same time changed to R134. It does not cool as well as it did with the original compressor, but close. The good thing is I can add R134 for about $5.00 a can and I can do it myself.
1fastredsc 06-12-2003 12:01 PM
I'm told that freeze 12 is supposed to be really good stuff. But i don't know first hand since i hate ac, roll down the windows, roll on the throttle!
scottb 06-12-2003 02:20 PM
Can anyone give me the correct brand and part number for a rotary compressor that will fit my 84 3.2?
Thanks.
