-   -   Dash panel rusted out mounting hole (http://forums.pelicanparts.com/porsche-911-technical-forum/1146143-dash-panel-rusted-out-mounting-hole.html)
zeneleven 09-11-2023 09:51 AM
A question for the sheet metal/rust gurus:
Is there a non-welding way to repair this rusty driver-side dash panel hole? It is the only one that looks like this, the other ones are all in good shape, and I'm wondering if I can do a decent job with a non-welding kit, knowing that the other mount points are solid.
http://forums.pelicanparts.com/uploa...1694454595.jpg
Uwon 09-12-2023 03:15 AM
Presume this is on your ‘71. I got the same year. Ugh! Man-oh-man……that’s the tip of the iceberg. Ask me how I know.
Johan
Dpmulvan 09-12-2023 05:35 AM
That rust needs to be cut out and new metal installed, there’s no way around it.
dannobee 09-12-2023 06:38 AM
It goes way deeper than that. And what remains is far thinner than the original metal.
You'll need to cut it all out and weld in new metal. No easy way around it.
eastbay 09-12-2023 07:57 AM
If you can't or won't weld, just follow the same steps (cut out bad, fab piece to fit) and pop rivet in a patch.
Can always come back to it later.
zeneleven 09-12-2023 12:55 PM
Thanks for the advice. I can do the weld, just not my strong suit. Every job is a learning opportunity!
zeneleven 09-14-2023 10:13 AM
And one final question - I haven't put a caliper on it yet. Does anyone know what gauge that sheetmetal is? Not sure it's the same as the other panels
john walker's workshop 09-14-2023 04:45 PM
20ga is easy to work with and will hold up fine.
zeneleven 09-15-2023 08:16 AM
Thanks - looking forward to a fun weekend welding the patch!
zeneleven 11-17-2023 08:45 AM
Not breaking any land speed records but I trimmed out the rusty patch and hand-fitted a 20 ga patch. I'll probably blast it first, then weld it in. Also uncovered a smaller 8mm square rust hole in the A-pillar joint which I guess I'll fill with weld material
http://forums.pelicanparts.com/uploa...1700242383.jpghttp://forums.pelicanparts.com/uploa...1700242740.jpg
http://forums.pelicanparts.com/uploa...1700243067.jpg
PeteKz 11-17-2023 11:14 AM
When you finish welding, drill a couple 1/4" hoes at the low points along the windshield pinch weld, to let water drain out. it will drain down into the frunk area, but should not be so much as to cause any problems there. You must prevent it from pooling under the dash panel, as you discovered the hard way.
zeneleven 11-20-2023 10:34 AM
Thanks PeteKz - super helpful. Any thoughts on filling in the the smaller rust hole with weld material? Just seems like patching would be too difficult.
PeteKz 11-20-2023 03:41 PM
It appears that the small hole next to the pinch weld is about where you want to have a drain hole anyway. I'd clean it out, treat it with rust remover, then coat it with something black. Between the dash pad and the windshield gasket covering that area, you probably won't even see it.
zeneleven 11-22-2023 06:39 AM
Ah . . . I see what you mean. I'm going to epoxy primer the entire interior, so if I clean out that hole (maybe when I blast) hit it with Afterblast, and epoxy prime it (along with drilling 1 or 2 others as you suggest) it sounds like it should work pretty well
