915 diff speed sensor mystery
New to the forum but have been learning a ton! Love it.
My speedo reads about 15% too slow. After some reading here I figured it was a dropped magnet on the disc mounted to the diff. Hooked up a volt meter to the speed sensor tonight and I only get 4 equally spaced connections per revolution of the wheel. Video here: https://youtu.be/hbA0JwQErqk?si=aVk-mwrEeKtV0CkO
No way I’m missing half my magnets. Any ideas? This was done with half the car jacked up and the trans in neutral. The car has an LSD but I don’t think that matters.
Old 09-05-2023, 07:08 PM
I think I answered my question… With on wheel on the ground, the diff will spin the wheel faster (2x faster) than the diff ring gear. So, when I turned the wheel through two revs the diff ring gear only made one rev. Looks like my magnets are all in place!
Old 09-05-2023, 07:33 PM
Use an ohm meter to check magnets. Open the rear tunnel cover, disconnect wires in the 2 position plastic wire holder and check wires from trans with the ohm meter. In neutral with both wheels off the ground.
Old 09-05-2023, 07:58 PM
Half of them could be missing. They're probably on the drain plug
You can remove the diff with the trans in the car and replace them
Epoxy them back in place
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 09-06-2023, 05:08 AM
gearhead
This.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-06-2023, 05:12 AM
Thanks all. Just to confirm for anyone with the same question. If one wheel is on the ground, the diff body will spin at half the rate of the wheel that's off the ground. So, you will only get 4 closed connections on the speed sensor when you rotate the wheel one revolution. You need to rotate it through two full rotations and make sure you get eight closed connections. If so, you have all of your magnets where they should be.
You can also check to see if you dropped magnets by seeing if you odometer is accurate. If the odometer is accurate and the speedo is not then it's the speedo and not an magnet issue. That was the case for me.
Old 09-12-2023, 11:30 AM
kevingross's Avatar
In this case, the dropped magnets created damage in other parts of the transmission. This "tone wheel" became available once more via Porsche Classic not too long ago.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 09-13-2023, 09:31 AM
