Brake rotor runout - truing front hubs
When I installed new rotors on my kit car, I seemed to need more brake pedal travel. At least one of the possible reasons is rotor runout, which I measured at .007". Not caused by the rotor, but caused by the hub and a mix of zinc paint and rust depositions and galvanic corrosion.
I was able to make an arbor and true the hub on a South Bend 9A, and rotor runout is .001-.002" now. The kit car has 4 piston calipers and does not have power brakes, so pedal travel is at a premium. I want as little as I can get! An alternate method, which I think was used on the kit car initially, is to install Hawk Blue pads or similar and drive around for a few hundred miles. I image that will machine the runout away also.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Galvanic corrosion is a real problem! Love your solution and your south bend. Looks like you are a handy machinist. The arbor and tapered cones are trick. Especially the threaded end to draw the cones into the hub
it's not leaking....it's just marking it's territory |
I have a southbend 9a decent little lathe, burger do you have the metric change gears? Was wondering how well they worked. Just wish I had another inch or two of swing to resurface heads.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
I agree, the 9A is a lovely machine but a tad small. Something 12" would be much nicer to have. Alas, room and transport becomes an issue. The 9A breaks down into carryable parts in 30 minutes. Mine dates to the early 40's.
