Speed sensor plug replacement
Hi,
As you can see below, my plugs are brittle and break very easily .
2 plugs have 3 wires and one has 2 .
Can i just cut and get new plugs like this :
https://amzn.eu/d/cTmS6Iy
Picture of the plugs :
Thx !!
Old 09-17-2023, 03:07 PM
Most folks get new sensors.
206 637 4071
Old 09-17-2023, 03:28 PM
Why? The other end is brittle too ..
Old 09-17-2023, 03:32 PM
lake wales fla
If your sensors are original I would suggest you buy new Bosch sensors online, they can be had in the $55- $60 range and while they are not specifically for 3.2 they fit perfectly and the only difference is the cables are longer.
Part# 0261 210 002
Richard
Old 09-17-2023, 03:40 PM
Thx for the advice .. but the ends that go to the dme are also broken ..
Old 09-17-2023, 03:47 PM
The sensors will get you half way and Timmy2 on the forum should have the female ends. Also, search kroonwireharnessess.com
206 637 4071
Old 09-17-2023, 05:59 PM
johnman001's Avatar
I used to get them from EagleDay.com, but it appears that they are gone now. These are called Junior Timer Connectors. You can google search for the housings, plugs and pins. Some of the other suggestions might work as well. Here is a quick search for 3 pin connectors such as are for the flywheel sensors. Note the retainer on these release much easier than the original retainer clips.
https://us.gsparkplug.com/durite-junior-power-timer-connector-female-3-way-bg1-0-012-73.html?wi=off&srsltid=AfmBOorFSCQD6BMTulGP1I6vCV5M4G_6pfY80tKGOz MRYjJQUOsMOIqw72I
Like others have suggested, I would recommend changing out the flywheel sensors if the plugs are crumbling.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 09-19-2023, 12:08 PM
rsscotty's Avatar
Another source....
https://www.corsa-technic.com/item.php?item_id=648
Old 09-19-2023, 12:12 PM
thx!
i ordered a set!
is there anything special about re-making the connections?
thx in advance !
Old 09-21-2023, 04:41 AM
