915 shift issues
I track a narrow body car with a short shift but stock shifter with a Sien spring assist. An event at Road Atlanta this past weekend, my shift into 3rd heading up to the bridge would balk 1 out of 2 laps. Then will not go into any gear, you are coasting, cars flying by on both sides, then eventually you find a gear and get going again. This has been an ongoing problem, but intermittently. Feels like I am hitting 2 gears, 3rd and 5th, 3rd and 1st, don't know. I make sure I have the shifter all the way over headed for 3rd against the spring resistance. I don't think a Stomski, Wevo shifter is going to fix this issue. I think the problem is between cup and socket and the little finger inside the gearbox selecting the shift rods. Any enlightenment would be greatly appreciated. Contemplating going with a turbo box this has become such a problem, but would love to find a solution with what I have. Thanks, Bob
Old 09-29-2023, 11:48 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
If the linkages are not work, check engine & trans mounts.
The weight of the engine and trans means they move on the mounts, especially on sticky tires on track. It’s a well documented early 915 problem. Stiffer engine mounts help, full on race cars likely run solid mounts.
Old 09-30-2023, 02:55 AM
Sounds like a shift rod adjustment. Either adjust to the 1-2 side or try adjusting to the 5-R side (I’ve had luck on a few occasions making that adjustment). The 5-R adjustment helps with 2 people, one to hold the lever against the spring pressure while the other makes the trans rod adjustment.
Old 09-30-2023, 09:03 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Check your tunnel for broken shift bushings…..
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 10-02-2023, 04:14 PM
