85 911 o2 sensor plug (HELP)
Hi Folks, I am in the middle of my engine service, I am having serious difficulty sourcing the o2 sensor socket (Harness side) for my 911. I sourced the very high quality single pin connector from Kroon in the Netherlands, but I have since realized that two pin socket (harness side) is broken and missing its outer half, this is the part where the rectangular two pin o2 sensor connector plugs in. I have been drawing a blank from Porsche and any of the other parts specialists, this is very annoying as I am sure it is a part that is used in many other German cars, the bosch sensor it's self has 928 part numbers on it. I have the bottom half of the socket that clips into the bracket, but not the outer half that has the serial numbers on it, the pics show the numbers on the inside that I found, but they don't bring up anything from porsche parts, I would greatly appreciate it if someone has a spare they would be willing to part with or at least look on their car for the appropriate part number.http://forums.pelicanparts.com/uploa...1696186805.jpg
http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg http://forums.pelicanparts.com/uploa...1696186805.jpg |
My car is a 1985 3.2 carrera. The bosch sensor is a 928-606-124-00-m14
Can someone take a photo of theirs?
Thanks Michael,I think the serial numbers might be under the hold down clip, I called Bosch today,as they are the only people I haven’t spoken to yet. They gave me the number for “Chief enterprises” that are their connector supplier. I have a call into them and I hope to speak with them tomorrow. I’ll let you know.
have a look at this, perhaps this might help
http://forums.pelicanparts.com/porsche-911-technical-forum/966292-help-correct-wiring.html |
These guys probably have it: https://www.ladismantler.com/carrera/
Well, your only options may be to either:
1. Find a 911 that is wrecked and salvage the connector from there, or 2. Use a different connector...maybe update to the later Carrera 3.2 style connector? |
See this link at Kroon, look closely at the picture and you will see that it has the connector you want at the bottom of the photo just above the DME connector. The listing says that it uses all new parts, so they clearly have a source for that connector. https://www.kroonwireharnesses.com/porsche-911/porsche-911-1984/dme-harness-for-porsche-carrera-32-m298-japan-o2-sensor-closed-loop-ctrl-artno-91161217306 If that does not pan out, then while you are trying to find the correct sensor I would splice in any good generic two wire connector to use so your car can run while you are looking for the correct connector. Like this: https://www.amazon.com/Sets-Waterproof-Connectors-Assembly-Harness/dp/B00M72QX82 |
If you have the pins and half of the connector cover, maybe you can find someone to 3D print the missing half of the connector? |
I have called every USA dismantler and 911 specialists that I can find, Also Porsche classic in Germany, and chief enterprises Bosch's US automotive parts supplier. I still can't source this part or even find the serial number, I really would prefer to keep this as original as I can, does anyone have any ideas?
OMG I think I just got one on Ebay, at long last....
| All times are GMT -8. The time now is 05:26 AM. |
